Rules for lights
Hi everybody,
I'm trying to set up a rule to turn on my backyard lights when the patio door opens to let the dog out. I'm able to have the lights turn on when the patio door open to let the dog out but I would also want then to close when I let the dog back in. If I tell the ISY to have the light open for 10 minutes after the door opens when I let the dog back in and open the door again it will start a new countdown.
Is it possible to have something in the rule that would not start a new countdown for when I open the door the second time to let the dog in?
This is what I have for now
Time is sunset +1hour
Or Time is Sunrise - 1minutes
And Elk Zone Patio Physical Status is Open
Set Balcony light On
Set pool house On
Wait 12 minutes
Set Balcony lights Off
Set pool house lights Off
I think I will stand by my suggestion on cocoontech. Did you try it?
what do you mean by:
then
Run second program (then path)
When one chooses a program under "action", there are choices that include "run (if)", "run then", and "run else". These refer to which of the three sections of a program (if, then, or else) to run. Once selected, it shows up in the program content as
Run Program "XXXX" (then path)
This is what I have done. The first program triggers when you open the door and the light is already off. If the light is already on, then nothing happens.
This calls the second program "else" path. After 10 minutes it beeps to warn you that the light is going to shut off. If you want it to stay on, you have to hit the "on" paddle and that will re-trigger the second program to run "true" which will abort the timer that shuts off the light.
       Program 'Dark Outside' is True
   And Elk Zone 'Front Door' is Violated
   And Status  'Foyer / Foyer-Portico Can L' is Off
       Run Program 'front door 2' (Else Path)
       Control 'Foyer / Foyer-Portico Can L' is switched On
       Set 'Foyer / Foyer-Portico Can L' 100%
       Wait  10 minutes
       Set 'Foyer / Foyer-Portico Can L' 250 (Beep Duration)
       Wait  30 seconds
       Set 'Foyer / Foyer-Portico Can L' Off
   And Status  'Foyer / Foyer-Portico Can L' is Off [color=#FF0040]***This is where I would indicate if patio lights are off, right?*****[/color]
       Run Program 'front door 2' (Else Path) [color=#FF8040]*** would I indicate open patio light and pool house lights here?***[/color]
       Wait  10 minutes
       Wait  30 seconds
Having a trouble setting this up. Made some comments directly on the above example. Thanks in advance for your help
This is the rule I programmed
If:
Program "Dark Outside" is true
and ELK Zone "Patio" "physical Status is open
and status "pool house" is off
and Status "shed spots" is off
Then:
Set "pool house" on
set "patio"on
Else:
wait minutes
set "pool house" off
set "balcony"off
I am not sure that it does all that you asked for (does it start a new countdown when you close the door, or when you open it a second time?), but if you are happy with it, then that is good enough for me.
I doubt your program is doing what you think it is. Every time you turn your pool house lights or shed spots on, that program will run and it will be false and the lights will shut off after the wait, even though the door was never opened or if "dark outside" is false. Also, at dusk, the dark outside program will change state and trigger the program to run false and the lights (if they were on) would shut off after the wait.
The goal of my program was to check the status of the light when the door was opened. If the light is already on, then the assumption is that it is on for a reason and we don't want it to shut off after the wait. If the light is off to start with, opening the door will turn it on and start the timer. You need two programs to do that.
You really need to do this with 2 programs. The reason is that you are going to have lots of un-intended runs of the "else" clause.
Thank you for the feedback and help. I'm having issues write the rule with 2 rules as per your example. Does the below sound right?
If :
Program «Dark outside » is true (program outside is: If between midnight and 6am)
And ELK zone “patio door†is open
And balcony light is off
And pool house light are off
Then Run program “pitbull in the yard†(Else path) (pitbull in the yard is, Else: open balcony and pool house lights)
2nd rule
This is where I’m confused. Does anything look at our place so far?
That looks fine. It will run the Else path on your second program if the door is opened while the lights are off.
In your second program just have the else path turn on the light you want, wait the number of minutes you want, and turn the light off.
In the "if" section put any conditions that you would like to have abort the wait.
Like
If balcony light is switched on
- - -blank
Set balcony light on
set pool house light on
wait 10 minutes
set balcony light off
set pool house light off
In this case, if someone pushes the "on" paddle of balcony light during the 10 minute wait, it will abort the wait and run the "then" clause. .. which is blank so it just does nothing.
cool perfect it works. Thanks everybody for your input.
I do have another question about writing rules. I have the below program, anything wrong with it?
Program Dark Outside is true
Run program Christmas Tree (if)
Set Christmas tree off
thanks everybody for your patience and help. Enjoying the learning. I wish I could find something I can read that would accelerate my learning and I wont really need to bug you all
Have you read the wiki? Have you read the user manual? Have you read the manuals that come with each device?
