SwitchLinc Dimmer - set fast on as default for single click?
Is there anyway to set 'fast on' as the default for a single click? if not, is there anyway to do it programmatically through ISY?
No.
You can activate an ISY Program with a SwitchLinc Dimmer On and set the device to Full On in response.
Something like this...
  Control SwitchLinc is switched On
  Set SwitchLinc FastOn
...should do what you want with a slight program delay. This does make me wonder what the use case is for this however. There very well may be a better solution to achieve what you want.
