KeypadLinc Status Lights Incorrect
stillen_i30
I have a scene where a keypad'd "Main" button controls kitchen lights.
I have several keypads whose versions are v.35 which have a button called "Kitchen Lights" which are supposed to update their backlit buttons to show if the kitchen lights are off or not off. For example, if I engage a scene which turns on the kitchen lights to 45% on level, I also want the "Kitchen Lights" buttons on all those keypads to turn on too, but despite my program, they will not turn on or off when the scene is activated. Here is a copy of my programs:
       Status  'Kitchen / Kitchen Overhead Lights' is not Off
       Set 'Home Theater / Home Theater Keypad B' On 12 / Off 6 (Backlight Level)
       Set 'Main Hallway / Main Hallway Lights 2 KPL / Main Hallway Foyer KPL B' On 12 / Off 6 (Backlight Level)
       Set 'Main Hallway / Main Hallway Lights 3 KPL / Main Hallway Stairs KPL B' On 12 / Off 6 (Backlight Level)
       Set 'Office / Office Lights Keypad - D' On 12 / Off 6 (Backlight Level)
       Status  'Kitchen / Kitchen Overhead Lights' is Off
       Set 'Home Theater / Home Theater Keypad B' On  0 / Off 6 (Backlight Level)
       Set 'Main Hallway / Main Hallway Lights 2 KPL / Main Hallway Foyer KPL B' On  0 / Off 6 (Backlight Level)
       Set 'Main Hallway / Main Hallway Lights 3 KPL / Main Hallway Stairs KPL B' On  0 / Off 6 (Backlight Level)
       Set 'Office / Office Lights Keypad - D' On  0 / Off 6 (Backlight Level)
What am I missing here?
The KPL Backlight level is NOT used to turn a Secondary button On or Off. Changing the Backlight level affects all buttons on the KPL, determining how Bright an On button is, not turning a button On or Off.
Define an ISY Scene and assign one or more Secondary KPL buttons to the Scene as Responders. Turn the ISY Scene On/Off to turn the KPL Secondary button(s) On/Off.
Hi stillen_i30;
I have (through the help of a few members here) two programs that I run to sync the KPL button LED to the status of the light.
First I have a scene that only has the KPL LED button in it as a responder.
Then I have these two programs.
       Status  'Hutch Lamplink' is Off
       Set Scene 'LED OFF Scenes / Hutch LED ON' Off
       Status  'Hutch Lamplink' is not Off
       Set Scene 'LED OFF Scenes / Hutch LED ON' On
As an aside, if there's an easier way to do it I'm open to hear it.
I hope this helps.
Drew
Using the "else" part of it?
Drew
Adding the 'else' line seemed to not work.
It seems like such a simple program.
But sometimes I'll walk into the room where the hutch is and see the LED on and the hutch light off (or visa versa)
I did it for these programs too.
       Status  'Andrew's Office A' is not Off
    Or Status  'Basement Hall' is not Off
    Or Status  'Basement KPL A' is not Off
    Or Status  'Christmas Tree' is not Off
    Or Status  'Lamp Left' is not Off
    Or Status  'Lamp Right' is not Off
    Or Status  'Library' is not Off
    Or Status  'Theatre Room' is not Off
    Or Status  'Marion's Office' is not Off
       Wait  1 second
       Set Scene 'LED OFF Scenes / BASEMENT LED OFF' On
and the opposite
       Status  'Andrew's Office A' is Off
    Or Status  'Basement Hall' is Off
    Or Status  'Basement KPL A' is Off
    Or Status  'Christmas Tree' is Off
    Or Status  'Lamp Left' is Off
    Or Status  'Lamp Right' is Off
    Or Status  'Library' is Off
    Or Status  'Theatre Room' is Off
    Or Status  'Marion's Office' is Off
       Wait  1 second
       Set Scene 'LED OFF Scenes / BASEMENT LED OFF' Off
but I find that sometimes the LED doesnt properly show the state of the light(s)
Drew
It is a simple program. The problem that typically comes up is when a path (THEN or ELSE) retriggers the program, but unless the scene "basement LED off" or "hutch LED on" includes devices that are part of the programs condition, then this should not be a factor.
Have you tried any experiments to further isolate the problem? Have you tried manually executing the THEN or ELSE paths to confirm that they work? Have you watched the program state from the ISY to see whether it is executing? Have you confirmed the ISY-presumed state of your devices match reality?
If the program appears accurate (and it does to me), then I start looking for other potential issues.
I'm unsure how to manually run the THEN and ELSE paths.
When I watch the ISY it seems to sometimes state that the program is on, other times, not.
I found that the LED would turn on, then off, then on, then off again (not flickering or flashing like when its sending a signal but not receiving)
I took out the 1 second delay and all the lights except two so I could test it easier than having to run around the basement.
It now seems to choose when to work.
Clearly I've made a mess of what seems to be simple.(?)
Drew
Right-click on the program name, choose run if, run else, whatever.
I was not so much concerned about watching the one or two seconds it was running, but more checking program status (true meaning last ran THEN path, false meaning last ran ELSE path) and last run times to determine that it last ran when you expected and how you expected. Toggle a few of your devices and see if the program reacts.
Also, look at any other programs you have to see if somehow they are unexpectedly reacting. Look for a program that runs several times in a row, going from true to false, causing your lights to turn on and off. Look for clues. Do you see anything that surprises you?
I continue to think that it is something other than these programs that are causing this.
