>Off vs Is Not Off
Sorry if this is a dumb question but what's the difference between status >Off vs Is Not Off?
Edit: Apologies. I misread the question
I would think that should be fairly obvious just one being the negative condition of each other.
The usual gotcha' on these logic conditions is the states in between on and off. If a lamp is dimmed to 0% it should be "not off" even though it looks off.
I don't have an ISY yet so I cannot test this for you (and me).
Just found this link in another thread. As a new user I thought it was worthwhile.
http://www.adamsj.com/isy/programming.htm
He wrote:
5. 'Not Off' is Different from 'On'
If you want to test if a light is illuminated at all, then you want to test for 'Not Off'. Performing a test for 'On' actually is testing for the light to be at 100%, which is probably not what you want.
bigscience
Are you asking in the context of "If Control" or "If Status"? It makes a difference.
larryllix
You might want to wait until you have an ISY and have a chance to actually work with one. Some of the posted information in this topic and another is not correct.
For Status, in a program I can choose >Off or Is Not Off. I get that 10% is not 'ON' but is >Off. I just don't get why there is an "is not off" when ">off" looks to do the same thing. Am I missing something? Is there a case where you'd use one over the other? Thanks for the help.
For Status "> Off" and "not = Off" would mean the same thing. For the other variations they could be different things. For example ...
If Status 'xxxx' > 20% versus If Status 'xxxx' not = 20%
produces different results. The > 20% means the On Level has to be greater than 20% to be True. For "not = 20%" means it is True if the On Level is below or above 20%.
I think the most common use of "is not off" is in a "status" line of a program when you want the program to run "true" for any partially on or totally on state.
These 2 are not the same program
status light x is not off *****light must be 1% or more to be true*****
do something
vs
status light x is on ****light must be 100% on to be true****
do something
Please realize that there are other ways to say the same thing.
The second use is in a control program when you want to run the "else" clause. This is much less common and is only needed when you have something of a more complex program with multiple conditions. But here it is
Control light x is switched off ***then clause runs when switched off, else clause never runs from this program****
do this
do that
control light x is not switched off ****else clause runs when switched off, then clause never runs from this program****
do this
do that
In the above, switching off is the one and only trigger, so when an "off" command is received, it is either true or false depending on the "not" being there. I sometimes use a "is not switched" condition as a condition to abort a timer.
control button a is switched on
and
control button b is not switched on
wait 10 minutes
do something
do blank
In the above, if you push button a, the timer starts, if you push button b, the timer aborts.
