Can't log in after Java update
Tried logging into the ISY at the usual local address xxx.xxx.x.x:xx/admin. This time, it said I needed to update java, so I followed the prompt and did so. It went to the legit Java site (no phishing) and I downloaded and installed the update. It completed successfully but now when I go to my ISY address, I get the following error and Java won't load:
Missing Application-Name manifest attribute for: http://192.168.1.7:99/web/insteon.jar
The full details window displays the following:
Java Plug-in 10.51.2.13
Using JRE version 1.7.0_51-b13 Java HotSpot Client VM
User home directory = C:\Users\Vinnie
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
If I do a system restore, it goes back to telling me I need to do the Java update. So now I can't get into the ISY either way. It either requires the update or I do the update and it fails to let me in with the error above.
I tried twice with the same results.
