cannot specify "program auto" mode on 2441TH thermostat
I have an ISY994i/firmware 4.1.0 with a wired Insteon 2441THR thermostat/rev 1.31.
( I also have a remote 2441THZ thermostat/rev1.2 linked to the ISY).
I cannot successfully set mode of operation (to "program auto") from an ISY program. I seem to be able to set mode to "heat".
I am using a command of the form -
Set "thermo-main" mode Program Auto
After executing the command, the thermostat goes to "heat" mode. Of course, I can manually move it to "program auto" mode by pressing the "mode" button on the thermostat.
I have been able to modify the temperature/setpoint settings successfully.
I believe that I have found a way around this problem by using scenes.
Set up a scene containing the "thermo main". Configure it the way I want the thermostat to be set- all the settings are available. By turning the scene "on" the thermostat seems to be reliably set into the modes I want.
