2334-232 Keypad Dimmer and ISY99i
I just installed a KPL6 2334-232 Keypad Dimmer, and find that my ISY99i is calling it a 2334-2 KeypadLinc Dimmer 5 Buttons. Looking around a bit, I get the feeling I need to get a ISY994i to support this device. Is that correct? I was under the mis-impression that I didn't need a new ISY994i unless I wanted some new capabilities, and the 99i could support all the various devices. I have a feeling I was wrong about that, but could someone confirm?
Dave
If you have the expected 5 nodes a 6 button KPL should have it is probably okay. However, there are devices not supported on 3.3.10 and that will only increase with time.
After I set it up on the ISY, it only shows as one node in the table, which operates correctly on the light that is hardwired as the load on the switch. I don't see the four A-B-C-D notes to use for scenes. though, which of course were the main reason for the KPL...
