Action after a Repeat
I am trying to figure out how to run an action after I do a repeat in my Then program. For example:
        Something Happens
        Sent email
        Repeat 4 times
             Set Scene 'Notifications' Fast On
             Set Scene 'Notifications' Fast Off
        Do something else AFTER but not in the Repeat <-------
Is it possible? I can't seem to indent it back to the left to be "out of the loop".
Rick
Ah! Thanks! I couldn't find that in the wiki.
A "Repeat 1" is the correct coding to end the preceding Repeat. Repeat 0 did not work.
Saw that in the wiki, should have corrected you... :)
As far as I can tell "repeat 0 times" is a non-functional command. If there is some use for it, I don't know what it would be. I would think that "0" should not be an option at all since it just confuses people.
