Unable to access isy99
When I tried to access my isy99 today I am getting;
Running this app may be security risk.......
If I select; I accept the risk....... and try to run I get an error
Missing required permissions manifest attribute in main jar:.......
Java 7.51, isy99 last supported update
Any thoughts?
Java has been updated to 51. Add the ISY IP address to the Java Exception Site List, under the Java Security tab. Another reason to update to a 994i. 4.1.2 contains the update Java 51 requires.
Lee,
As always, many thanks!!
Have the 994i sitting on the shelf, guess it is time to put it to use!
Same problem here. I can connect to the ISY using the IP address, but the Java app fails. It was working fine on Saturday, but failed when I tried logging in today. I'm guessing I need to follow LeeG's advice, but...how?
Can someone provide a little more detail on where add the IP to the Java Exception Site list?
Bernman
*Edit*
Found the answer after searching for a bit. Here is the forum thread for anyone looking for how to find the Java exception site list.
http://forum.universal-devices.com/viewtopic.php?f=25&t=13650
Adding the address seems to have fixed my console access problem.
