Mac and Column Sorting Function
Michel,
I know that this post was started again in the update forum.
I have updated my Java to the latest for the Mac. I have the new 6.0 Java and I am running the latest Safari and the new Firefox 3.0.
I just checked the sorting function in the different screens.
I can sort columns on the Device Screen, but not on the Programs Screen. this would indicate a problem in the program and not the Java capability of the browser. Please check and let me know if I'm wrong.
Clarence Martin
Hello Clarence,
Thanks for letting us know; I sure will let you know ...
Michel,
Clarence Martin
Michel,
Clarence Martin
Hi Clarence,
Do you see the text "Click Column Heading to Sort" beside the Edit | Refresh buttons on the program summary screen?
If you don't see it then it doesn't think Java 6 is being used. If you do then there is some other problem.
Chris,
I really don't remember seeing that option. I do remember using the Edit and Refresh buttons though.
I will have to check later today when I get Home.
Clarence
Chris,
There is no text "Click Column Heading to Sort" beside the Edit | Refresh buttons.
Just checked. Like I said, the Edit and Refresh buttons do exist and they work.
Clarence
Chris,
Another thing....
The column headers do not highlight when I mouse -over them like the PC Browsers.
This missing element is also missing on the Device page - that allows column sorting.
Clarence
For some reason it does not recognize you as using Java 6. Can you do the following on your Mac:
1) Open the Java console
2) In the Java console type 's' (You will see a bunch of values written e.g "java.version = 1.5.0_13")
3) Copy all the entries beginning with java. and paste them in a response here.
Sorry Chris,
exactly where do I do this?
I opened the java folder under the Utilities folder under the applications folder.
I don't see a place to type in the 's' that you mentioned.
Am I in the right place?
This is the same place where i delete the temp files.....
Clarence
OK,
I was able to have the Java Console open and here are the results:
Java Plug-in 1.5.0
Using JRE version 1.5.0_13 Java HotSpot Client VM
User home directory = /Users/chipsm
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
Dump system properties…
acl.read = +
acl.read.default =
acl.write = +
acl.write.default =
apple.awt.graphics.UseQuartz = false
awt.nativeDoubleBuffering = true
awt.toolkit = apple.awt.CToolkit
browser = sun.plugin
browser.vendor = Sun Microsystems, Inc.
browser.version = 1.1
file.encoding = MacRoman
file.encoding.pkg = sun.io
file.separator = /
file.separator.applet = true
gopherProxySet = false
http.agent = Mozilla/4.0 (Mac OS X 10.5.3)
http.auth.serializeRequests = true
https.protocols = SSLv3,SSLv2Hello
java.awt.graphicsenv = apple.awt.CGraphicsEnvironment
java.awt.printerjob = apple.awt.CPrinterJob
java.class.path =
java.class.version = 49.0
java.class.version.applet = true
java.endorsed.dirs = /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/endorsed
java.ext.dirs = /Library/Java/Extensions:/System/Library/Java/Extensions:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/ext
java.home = /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home
java.io.tmpdir = /tmp
java.library.path = .:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
java.protocol.handler.pkgs = sun.plugin.net.protocol|com.sun.deploy.net.protocol
java.runtime.name = Java 2 Runtime Environment, Standard Edition
java.runtime.version = 1.5.0_13-b05-237
java.specification.name = Java Platform API Specification
java.specification.vendor = Sun Microsystems Inc.
java.specification.version = 1.5
java.vendor = Apple Inc.
java.vendor.applet = true
java.vendor.url = http://www.apple.com/
java.vendor.url.applet = true
java.vendor.url.bug = http://bugreport.apple.com/
java.version.applet = true
java.vm.info = mixed mode
java.vm.name = Java HotSpot Client VM
java.vm.specification.name = Java Virtual Machine Specification
java.vm.specification.vendor = Sun Microsystems Inc.
java.vm.specification.version = 1.0
java.vm.vendor = Apple Inc.
java.vm.version = 1.5.0_13-119
javaplugin.maxHeapSize = 96m
javaplugin.nodotversion = 150
javaplugin.proxy.config.type = direct
javaplugin.version = 1.5.0
javaplugin.vm.options = -DtrustProxy=true -Xverify:remote -Xbootclasspath/a:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/deploy.jar
:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/plugin.jar -XX
:-UseSharedSpaces -Djavaplugin.nodotversion=150 -Djavaplugin.version=1.5.0 -Xmx96m -Djavaplugin.maxHeapSize=96m
line.separator = \n
line.separator.applet = true
mrj.version = 1040.1.5.0_13-237
os.arch = i386
os.arch.applet = true
os.name = Mac OS X
os.name.applet = true
os.version = 10.5.3
os.version.applet = true
package.restrict.access.com.sun.deploy = true
package.restrict.access.netscape = false
package.restrict.access.org.mozilla.jss = true
package.restrict.access.sun = true
package.restrict.definition.com.sun.deploy = true
package.restrict.definition.java = true
package.restrict.definition.netscape = true
package.restrict.definition.org.mozilla.jss = true
package.restrict.definition.sun = true
path.separator = :
path.separator.applet = true
sun.arch.data.model = 32
sun.awt.exception.handler = apple.awt.CToolkit$EventQueueExceptionHandler
sun.boot.class.path = /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/classes.jar
:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/ui.jar
:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/laf.jar
:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/sunrsasign.jar
:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/jsse.jar
:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/jce.jar
:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/charsets.jar
sun.boot.library.path = /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries
sun.cpu.endian = little
sun.cpu.isalist =
sun.io.unicode.encoding = UnicodeLittle
sun.jnu.encoding = MacRoman
sun.management.compiler = HotSpot Client Compiler
sun.net.client.defaultConnectTimeout = 120000
sun.net.http.errorstream.enableBuffering = true
sun.os.patch.level = unknown
trustProxy = true
user.country = US
user.dir = /
user.home = /Users/chipsm
user.language = en
user.name = chipsm
user.timezone = America/Los_Angeles
Dump deployment properties…
deployment.apple.java10.5.u1 = true
deployment.apple.special = true
deployment.browser.args = -raise -remote openURL(%u,new-window)
deployment.browser.path = /Applications/Safari.app
deployment.cache.jarcompression = 0
deployment.cache.max.size = -1
deployment.capture.mime.types = false
deployment.console.startup.mode = SHOW
deployment.control.panel.log = false
deployment.home.j2se.url = http://java.sun.com/j2se/
deployment.javapi.cache.enabled = true
deployment.javapi.cache.update = true
deployment.javapi.lifecycle.exception = false
deployment.javapi.log.filename =
deployment.javapi.runtime.type = 0
deployment.javapi.trace.filename =
deployment.javaws.associations = ASK_USER
deployment.javaws.autodownload = NEVER
deployment.javaws.home.jnlp.url = http://java.sun.com/products/javawebstart
deployment.javaws.installURL = http://java.sun.com/products/autodl/j2se
deployment.javaws.logFileName =
deployment.javaws.muffin.max = 256
deployment.javaws.shortcut = ASK_IF_HINTED
deployment.javaws.ssv.enabled = true
deployment.javaws.traceFileName =
deployment.javaws.uninstall.shortcut = false
deployment.javaws.update.timeout = 1500
deployment.javaws.viewer.bounds = 480,285,720,360
deployment.log = false
deployment.mime.types.use.default = true
deployment.proxy.bypass.local = false
deployment.proxy.override.hosts =
deployment.proxy.same = false
deployment.proxy.type = 3
deployment.repository.askdownloaddialog.show = true
deployment.repository.enabled = true
deployment.security.SSLv2Hello = true
deployment.security.SSLv3 = true
deployment.security.TLSv1 = false
deployment.security.askgrantdialog.notinca = true
deployment.security.askgrantdialog.show = true
deployment.security.authenticator = true
deployment.security.browser.keystore.use = true
deployment.security.clientauth.keystore.auto = true
deployment.security.jsse.hostmismatch.warning = true
deployment.security.sandbox.awtwarningwindow = true
deployment.security.sandbox.jnlp.enhanced = true
deployment.security.trusted.policy =
deployment.system.security.cacerts = /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/security/cacerts
deployment.system.security.jssecacerts = /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/security/jssecacerts
deployment.system.security.trusted.certs = /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/security/trusted.certs
deployment.system.security.trusted.clientauthcerts = /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/security/trusted.clientcerts
deployment.system.security.trusted.jssecerts = /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/lib/security/trusted.jssecerts
deployment.trace = false
deployment.update.mime.types = true
deployment.user.cachedir = /Users/chipsm/Library/Caches/Java/cache
deployment.user.extdir = /Users/chipsm/Library/Caches/Java/ext
deployment.user.logdir = /Users/chipsm/Library/Caches/Java/log
deployment.user.security.policy = file:///Users/chipsm/Library/Caches/Java/security/java.policy
deployment.user.security.trusted.cacerts = /Users/chipsm/Library/Caches/Java/security/trusted.cacerts
deployment.user.security.trusted.certs = /Users/chipsm/Library/Caches/Java/security/trusted.certs
deployment.user.security.trusted.clientauthcerts = /Users/chipsm/Library/Caches/Java/security/trusted.clientcerts
deployment.user.security.trusted.jssecacerts = /Users/chipsm/Library/Caches/Java/security/trusted.jssecacerts
deployment.user.security.trusted.jssecerts = /Users/chipsm/Library/Caches/Java/security/trusted.jssecerts
deployment.user.tmp = /Users/chipsm/Library/Caches/Java/tmp
deployment.version = 6.0
Done.
Hi Clarence,
It appears as though you are using Java 5:
I don't have access to a Mac with Java 6 at the moment, but I believe the following to be the solution:
I assume you have installed Java 6, but it may still be using Java 5 for the Java Applet Runtime Settings:
1) Close the ISY Admin console
2) Using Finder->Applications->Utilities->Java->J2SE 6.0? ... Open the Java Preferences window and go to the General tab
3) Ensure that Java 6 is selected in the Java Version section of the Java Applet Runtime Settings
4) Hit the 'Save' button
5) Restart the Mac
Start the ISY Admin Console again and see if the sorting in the Program Summary works.
Hi Chris,
I went back to the Java console and did have to make one change. In one of the dialog boxes, I had to re-order my preferences for the version of Java to run first. But, to no avail... no sorting available.
So now Java 6.0 is the first in the list.
I'm feeling kind of dumb at this moment.
Clarence
Chris,
It still doesn't work.
I can't seem to get this one right.
Clarence
I'm upgrading to Leopard 10.5.4 now, and when I'm done I should be able to debug this problem a little better. In the meantime ...
In the Java Preferences window you have moved Java 6.0 to the top of the Java Application Runtime Settings list. Above that on that on the screen is a radio button selection of which Java version to use. Make sure you have selected Java 6.
After making these changes, you must reboot the Mac to start using them.
Chris,
Thanks for this effort.
I did all that you said with the Java Console.
Now, I will wait until you get our system upgraded we will kick this thing around again.
Let me know when you have your system up to date.
Again, thanks...
Clarence
Hi Clarence,
The good news is Java 6 is available on Mac, but the bad news is Safari (and I think FireFox as well) does not support it, and thus will only use Java 5.0 when running applets.
Sorry for the runaround ... I'll let you know if I find a way to launch the applet using Java 6 on the Mac.
Chris,
Thanks again.
I did a search for Mac Browsers and the news is not good. The two most popular and supposedly the greatest are Safari and Firefox.
I am having some difficulty making Firefox open " my lighting". I am surprised that Apple hasn't kept up with Java's updates - Oh Well..
For such a sophisticated OS to have such slow software updates... I guess this proves that even Apple has abysses where things fall into. Hopefully not too far down though.
Let me know what you find.
Clarence
