Cannot access ISY-26 from laptop wirelessly?
I can't seem to access the ISY-26 from my laptop through wireless. I can see the "my Lighting" icon in my network places but I get an error saying the device is not available on the network? Works fine through wired network.
Turns out i cannot get in to the ISY wired or wirelessly! I just installed 2.6.5, I will try a few things to figure this out!
I'm having the same troubles as others are with the update.I can get in with the /27
When I log into the ISY-26 from my laptop wirelessly, I get the following error:
(Event received for a different subscription; Restart! uuid:6) I only get this error from the laptop wirelessly.
keribi,
This is quite strange!
1. Would you be kind enough to clear the Java cache on your laptop?
2. Would you please make sure you do not have ports 443 or 80 routed to any other device on your network
