Folders
Hi Michel:
Decded to do some housekeeping and changed my original programs to folders (1) Home, (2) Away. Get the baics of it OK, but they wouldn't run right. In a nutshell what I did was;
Made a folder AWAY,
Made the criteria for the folder as "when KPL A is OFF, run programs within.
Here is the new folder:
Folder Conditions for 'AWAY'
Add conditions to limit when programs in this folder are allowed to run.
Status 'GAR KPL H' is Off
Or Status 'MBR KPL H' is Off
Or Status 'Occupied On/OFF APL' is Off
And finally, I placed this program in the folder to run:
nothing
Repeat Every 15 minutes
Set Scene 'All OFF' Off
They would not run properly...
Here is the original program as it has run for a year:
Is it possible my old version is to blame? or do I have parenthasis out of whack. I just want to re-do ISY so I have a better HOME/AWAY housekeeping. Any ideas of what I'm doing wrong?
aLf
aLf,
Your posted code will enable the folder but your program lacks a trigger to start it (unless you are calling the program from another program). Each program requires an "Event" or a specific call from another program to start.
The following will trigger if any of the "somethings" change state to ">0". You do not need the repeat loop here since the program will trigger if any of the monitored devices transitions from the off state.
      status "something1" is > 0
   or status "something2" is > 0
    o
    o
    o
    or status "somethingx" is >0
       Wait 15 minutes
Regarding your question about your "old" version - Yes this can make a difference. Firmware Version 2.6.4 corrected a problem related to status updates for disabled folders.
Here's a thread on the subject -
http://www.forum.universal-devices.com/viewtopic.php?p=8687#8687
Bottom line is, if you are running firmware older than 2.6.4, you may want to update.
IM
Hi Michel:
Made a folder AWAY,
nothing
aLf
Decided to do some housekeeping and changed my original programs to folders (1) Home, (2) Away. Get the baics of it OK, but they wouldn't run right.
Hi Alf,
You need something to trigger this program to run. As of v2.6.6, this is very easy to do with Folders.
If you want the program in the Folder to run when the Folder Conditions become True then just put that in the conditions of the program.
      Folder 'AWAY' is True
Indy & Chris:
Thanks! First I have not upgraded yet for other reasons. I will eventually. Just under my AWAY circumstances, I can't afford a bug--yet. When I can upgrade, I will.
I now understand your reasoning on the folders, thank you. I will change it over now and hope that it works better.
Regards,
aLf
Chris,
Thank you as well. I've been on the road a lot lately and missed the 2.6.6 folder condition update.
Very nice! Can't wait to get home and give it a try.
