Every 3rd day
Using an ISY994i controller how do I make an event happen every 3rd day?
I would use an integer variable. Set it to 0, and increment it by 1 every day at a given time (say 1 AM), and set the init value to the new value.
Then at whatever time you want something to happen, have another program that checks the current time AND if the variable is set to 3 or more. The if clause would take whatever action you want, and then set the variable (and init value) back to 0.
Then, given an example of something happening at 7 AM, the timeline would be:
Day1 - @1 AM - variable increments to 1
Day1 - @7 AM - variable is less then 3, program doesn't run
Day2 - @1 AM - variable increments to 2
Day2 - @7 AM - variable is less then 3, program doesn't run
Day3 - @1 AM - variable increments to 3
Day3 - @7 AM - variable is 3, program runs, resets to 0
Day4 - @1 AM - variable increments to 1
Day4 - @7 AM - variable is less then 3, program doesn't run
Day5 - @1 AM - variable increments to 2
Day5 - @7 AM - variable is less then 3, program doesn't run
Day6 - @1 AM - variable increments to 3
Day6 - @7 AM - variable is 3, program runs, resets to 0
Make sure that whenever you increment the variable (or set it to 0), you also increment or set the Init value - so the sequence survives reboots....
