Network module advice
I have an itach that I use to control our playroom tv with roomie remote. I want to be able to turn off the tv when I fast off the playroom lights or at bedtime. Houselinc was able to see to control one of my itachs (buggy software would use properties of the first itach for the second.).
Is this as simple as adding the network module then using the how to guide to add the remote codes. Are any of you using the network module to control itachs.
Advice on this would be appreciated.
Eric
I am using the itach with several network resources to control my samsung tv and a blue ray player. I can post some details when i get home.
-Xathros
Thanks. The other night the tv was left on for a few ours after the kids watched a show before bedtime. The isy can fix that problem.
It certainly can. I have a program that runs daily just before midnight and among other things, shuts down my AV stuff in the living room.
-Xathros
  • 1 month later...
Xathros,
I bought the network module yesterday and posted in the IR thread.  I have a program to shut down the playroom tv at night.
I may work on the theater since my projector is controlled by IR and the receiver is IR +IP, both via iTach.  Ill just have to learn the IR codes and add shutdown to my all off button..  BluRay is IP only so that will take some more work.
Eric
