Scene Turns on Device not in the Scene
I have the following scene called 'Downstairs - Kitchen'.  As you can scene from the image attached below it contains a Dual Band Switchlinc (20.93.9B) and a Remotelinc Button A (0A.0A.64)
My problem is when I trigger the 'Downstairs - Kitchen' scene on or off, it not only turns on or off switchlinc (20.93.9B) but it also turns on or off a Dual Band Outlinc Dimmer (2A.74.1C) thats not even in the scene.
I am sure I don't have any other programs or scences that would also trigger the Dual Band Outlinc Dimmer (2A.74.1C) on or off.
When I do a scene test on the 'Downstairs - Kitchen' scene this is the result:
Sun 07/13/2014 08:46:59 PM : [GRP-RX      ] 02 61 1B 13 00 06
Sun 07/13/2014 08:46:59 PM : [iNST-SRX    ] 02 50 2A.74.1C 23.98.41 61 13 1B    LTOFFRR(1B)
Sun 07/13/2014 08:46:59 PM : [std-Cleanup Ack] 2A.74.1C-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sun 07/13/2014 08:47:00 PM : [CLEAN-UP-RPT] 02 58 06
Sun 07/13/2014 08:47:00 PM : [iNST-SRX    ] 02 50 20.93.9B 23.98.41 62 13 1B    LTOFFRR(1B)
Sun 07/13/2014 08:47:00 PM : [std-Cleanup Ack] 20.93.9B-->ISY/PLM Group=0, Max Hops=2, Hops Left=0
----- Downstairs - Kitchen Test Results -----
[ignore]
Remote Grey - Button A (A A 64 1)
[succeeded] Downstairs - Kitchen (20 93 9B 1)
Not sure wha this means but I do see the address for the Dual Band Outlinc Dimmer (2A.74.1C) in the second line.
How to I trouble shoot this and correct it?
The plot thickens.  Within ISY I deleted the scene and recreated it.  All works fine, I now use the Remotelinc Button A (0A.0A.64) and it turns on and off the Dual Band Switchlinc (20.93.9B) only.
However, when I use Mobilinc to trigger the scene it turns on both the Dual Band Switchlinc (20.93.9B) and also the Dual Band Outlinc Dimmer (2A.74.1C) again.   I did a re-sync with Mobilinc (download all) and still the issue pesists.  Compeltely stumped.
