RemoteLinc2: Overriding dimming
Hello everyone,
First post (of many to come I'm sure). Had a hopefully quick question regarding the RemoteLinc operation. I've just gutted out entire x10 system and replaced it with this new beast.
I've programmed a 8 scene remotelinc 2 to toggle 8 different scenes. My dad will be using this as his primary way of getting things on and off. All the devices on this particular remote are simple on/off devices (no dimming). Here's the problem. My dad has MS and one of his symptoms is that he can't really sense pressure or touch. when he was clicking a button, nothing was working. Then I noticed that he was actually holding the button down longer than a typical click (which in remote terms i think it was assuming he was trying to DIM. So the device never turned on (or off). So here's the question:
Can I intercept the longer press and have a program just use that as a ON (or OFF), or is something else going on here? (The remote does work with a simple quick click... It's the prolonged press that's messing things up.
While I'm at it, I noticed that since the remotelinc is just a sender (no way to know if something is on or off) I should have the key press simply be a keypress (neither on or off) and have a program do the toggle? If so, how?
Be gentle... Thanks in advance.
Garrett
Can be done with a series of Programs to handle simple press or longer Fade Up or Fade Down.  Each press On/Dim/Bright will toggle the controlled device On then Off regardless of how long the button is held.
Put the RemoteLinc2 into 8 Scene non-toggle mode.   Fewer button possibilities.
RL2ButtonAOn
             Control '1C.2A.4A - B / 1C.2A.4A - A' is switched On
          Or Control '1C.2A.4A - B / 1C.2A.4A - A' is switched Fade Up
          Or Control '1C.2A.4A - B / 1C.2A.4A - A' is switched Fade Down
    And Status  'SwitchLinc Relay' is Off
        Set 'SwitchLinc Relay' On
RL2ButtonAOff
    And Status  'SwitchLinc Relay' is On
        Set 'SwitchLinc Relay' Off
Need 14 more Programs, two for each button, for buttons B-H
Edited by LeeG
@LeeG
Sorry for the bit of a sidetrack but...
  What is the difference between Dim/Brighten vs Fade Down/Fade Up.
I have only used them a few times and just tweak usage until they function as desired, so far.
Less typing.  Sorry if that raised a question.  There is a difference in what can be sent to a Dimmer from a Program.   A Set 'xxxxx' Dim is different from Set 'xxxx' Fade Down / Set 'xxxx' Fade Stop.  However, Dim/Bright commands are not sent by the RemoteLinc2.
To be accurate I should have said On/Fade Up/Fade Down rather than On/Dim/Bright.
Edited by LeeG
Whatcha'  drinkin' on a Saturday night? :-P  You did!
Thank you LeeG!!! I'm going to give this a whirl next couple days.
One other question: looking at your program, I can see 3 diff key presses, on fade up and fade down. When the remotelinc is put in non-toggle mode! then I guess a key press is always sent as on (there is no off). Correct?
Awesome. Thank you.
Any time.   I did not include Fast On which is physically possible if a button is tapped twice quickly.  Did not seem likely in the described circumstance.
So far it doesn't look like he's double tapping
