KPL solution but no explanation
I recently installed 5 KPLs 2486 V2C some in 8 some in 6 button mode.
I noticed when button controllig load is ON, using All Off is changing state to Off in the Admin panel, but light is still ON. Quering state again will change state of the KPL to ON again
Going to device panel in Admin console OFF will change state to OFF and turn off load as well.
I created scene TEST to which I added KPL load controlling button as responder. Now pressing All Off will turn load off and change state to off as well.
I created scene ALL where I added all devices and now All Off physically is turning load on all KPLs. I reconfirm that phenomenon by removing some of KPLs from the scene and duplicated problem of not switching load off wilth All Off commnad on above mentioned KPLs. I wonder if anybody experience behaviour like this and where the problem is (ISY 99iPro 2.6.6 or KPL).
Best regards Walter
Thanks Walter
Hello Walter,
The problem is that All Off (sending an off command to group 255) requires that a device to be in at least one scene. The status of the device is determined by the on level of the "last" scene it was linked to. As such, what you see is completely normal: your KPL has to be in a scene before it responds to an All Off.
This said, however, ISY should reflect the state correctly. This is considered a bug (thanks for finding it) and shall be rectified.
Thanks and with kind regards,
Best regards Walter
Thanks Walter
