Updating Firmware (Edited; Firmware is 4.2.2)
I am currently running firmware 4.2.2 on a MacBook Pro (OS 10.9.4). My ISY is a 994i IR Pro. I recently received and linked one of three Hidden Door Sensors. The procedure was successful and as I continued the setup I learned that nodes for the device required firmware 4.2.3 or higher. As I have researched updating the firmware I have taken note of posts that indicate that Safari does not play well with the firmware. So, I have installed Firefox and made it my default browser. I have also ensured that I have the most recent JAVA update (JAVA 7 Update 67). All my devices are Insteon or X-10 (I have the module installed). I am a novice at such matters so please take that into account as I ask a couple of questions. With Firefox set as my default browser does that ensure its use rather than Safari and resolve the problems mentioned in the aforementioned posts? I plan to use Appendix D: Upgrading Your Firmware from the User Guide to proceed with the update. Are those procedures up-to-date or are there other factors I need to take into account? Which firmware update is recommended as solid and dependable and will supply the nodes needed for the Hidden Door Sensors?
I have also noticed elsewhere that I should be getting automatic notices of updates. I have received none. Is there a setting I must make to get these?
Please note that I have made a clone of my harddrive and a backup of the ISY.
Sorry that my initial post said in error I was running 4.2.10.
Edited by smokegrub
I am currently running firmware 4.2.10....
You have the latest firmware version.
I have never received update notices either. I don't know where one would receive them. Just watch this forum for notices.
I do receive the upgrade announcements.  I believe there was a place on the UDI website to register for them - this was years ago.  I'll see if I can find that for you.
I would install the current beta 4.2.10 or wait for the 4.2.11 which I suspect will be the final within a week or 2.
-Xathros
EDIT: Register here:http://www.universal-devices.com/my-account/
Edited by Xathros
Please note the edit to my initial post. I made an error. I am running 4.2.2 not 4.2.10!
Thanks, Xathros. I amended my registration to request the firmware notifications.
Please note the edit I made to my original post. Senior moment!
  • 11 months later...
Hi,
I don't seem to find the 'Automatic Updates' that according to the documentation is supposed to be located from the Admin Console under the Help tab?
Is it now just automatic and you don't have a choice and the menu option was removed?
Thank you!
Rob
Most likely only the Pro version of ISY
I own the ISYi ZW/IR PRO?
Update: running 4.2.30
Edited by rlanza1054
Rob,
You won't get that unless we have an official release. Currently, the last official release is 4.2.30.
Hi,
So your saying that I will not see an option in the Help tab for Automatic Update, until there is an update?
So when there is another official update, my current ISY which is running that latest current release of 4.2.30, will then show that option in the Help tab?
Rob
And, you will be presented with a pop up dialog when logging in to the ISY to alert you to the availability of the update as well.  As Michel said, only for final releases not beta versions.
-Xathros
