Java Security Exception when accessing admin console
Hi Guys.  I've been a casual user of the ISY for a little bit and have recently run into a problem with the latest java update when trying to access the admin console through my ISY.  I can access the admin console through the universal devices website.
Everytime I go to access the admin console through my ISY, I get the following Java error.
"Missing Required Permissions Manifest in main Jar http://isy/web/insteon.jar"
I have flushed my Java cache and even when I try to reload it, I get the same error.
Maybe some out there with some more technical knowledge can help me out?  It would be greatly appreciated.
Thanks for your time
  • 1 month later...
I have the same problem. I updated Java and added my IP to the exception list but still get application blocked for security
Do you have your IP address of your ISY locked down in the DHCP table in your router? If your dynamically allocated  IP in your ISY changes, allowing the old IP through, it will not help.
What platform are you on?  Mac/Windows/Linux ?
-Xathros
Windows and yes it's a static IP. With the same IP set for the exception I can get to the web interface just can't get open the admin consol
If you've updated, then you need to reinstall the Admin Console (Settings).
Do you mean add it to the exception list? I removed it from the list and added it again but still get the same error message.
