Basic Question on How to Test a Scene
oronomus
Having trouble with a scene and need to make sure I fundamentally understand how things work.  I have a simple two-device scene with a togglelinc as a controller and a lamplinc as controlled device.  What I want is for the lamp to turn on and off when the togglelinc is switched on or off.  I have tested the scene - results below.  It shows successful.  But when I manually switch the Togglelinc the lamp does not respond.  Controller (toggleinc) is 25.8A.65 (labeled: Master Vanity Five Small Cans) in the below.  Lamplinc is 26.9B.AB (labeled: Master Vanity Lamp) .
SCENE TEST:
Thu 09/11/2014 12:17:03 PM : [GRP-RX      ] 02 61 51 13 00 06
Thu 09/11/2014 12:17:04 PM : [iNST-SRX    ] 02 50 26.9B.AB 23.98.2B 61 13 51    LTOFFRR(51)
Thu 09/11/2014 12:17:04 PM : [std-Cleanup Ack] 26.9B.AB-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Thu 09/11/2014 12:17:04 PM : [CLEAN-UP-RPT] 02 58 06
Thu 09/11/2014 12:17:04 PM : [iNST-SRX    ] 02 50 25.8A.65 23.98.2B 61 13 51    LTOFFRR(51)
Thu 09/11/2014 12:17:04 PM : [std-Cleanup Ack] 25.8A.65-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
<html><font color="red">----- Master Vanity Lamp Test Results -----</font></html>
<html><font color="red">[succeeded]</font> Master Vanity Five Small Cans (25 8A 65 1)</html>
<html><font color="red">[succeeded]</font> Master Vanity Lamp (26 9B AB 1)</html>
Thu 09/11/2014 12:17:11 PM : [iNST-ACK    ] 02 62 00.00.51 CF 13 00 06          LTOFFRR(00)
MANUALLY SWITCH TOGGLELINC
Thu 09/11/2014 12:18:19 PM : [iNST-TX-I1  ] 02 62 25 8A 65 0F 11 FF
Thu 09/11/2014 12:18:19 PM : [iNST-ACK    ] 02 62 25.8A.65 0F 11 FF 06          LTONRR (FF)
Thu 09/11/2014 12:18:20 PM : [iNST-SRX    ] 02 50 25.8A.65 23.98.2B 2B 11 FF    LTONRR (FF)
Thu 09/11/2014 12:18:20 PM : [std-Direct Ack] 25.8A.65-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 09/11/2014 12:18:20 PM : [D2D EVENT   ] Event [25 8A 65 1] [sT] [255] uom=0 prec=-1
Thu 09/11/2014 12:18:20 PM : [  25 8A 65 1]       ST 255
Thu 09/11/2014 12:18:20 PM : [D2D-CMP 003E] STS [25 8A 65 1] ST op=3 Event(val=255 uom=0 prec=-1) > Condition(val=155 uom=0 prec=-1) --> true
Thu 09/11/2014 12:18:35 PM : [        Time] 12:18:36 2(0)
Thu 09/11/2014 12:18:54 PM : [iNST-TX-I1  ] 02 62 26 9B AB 0F 19 00
Thu 09/11/2014 12:18:54 PM : [iNST-ACK    ] 02 62 26.9B.AB 0F 19 00 06          LTSREQ (LIGHT)
Thu 09/11/2014 12:18:55 PM : [iNST-SRX    ] 02 50 26.9B.AB 23.98.2B 2B 0D 00           (00)
Thu 09/11/2014 12:18:55 PM : [std-Direct Ack] 26.9B.AB-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Thu 09/11/2014 12:18:55 PM : [D2D EVENT   ] Event [26 9B AB 1] [sT] [0] uom=0 prec=-1
Thu 09/11/2014 12:18:55 PM : [  26 9B AB 1]       ST   0
Thu 09/11/2014 12:18:55 PM : [D2D EVENT   ] Event [26 9B AB 1] [OL] [255] uom=0 prec=-1
Thu 09/11/2014 12:18:55 PM : [  26 9B AB 1]       OL 255
Thu 09/11/2014 12:18:55 PM : [D2D EVENT   ] Event [26 9B AB 1] [RR] [27] uom=0 prec=-1
Thu 09/11/2014 12:18:55 PM : [  26 9B AB 1]       RR  27
Thu 09/11/2014 12:19:00 PM : [iNST-TX-I1  ] 02 62 25 89 8D 0F 19 00
Thu 09/11/2014 12:19:00 PM : [iNST-ACK    ] 02 62 25.89.8D 0F 19 00 06          LTSREQ (LIGHT)
Thu 09/11/2014 12:19:00 PM : [iNST-SRX    ] 02 50 25.89.8D 23.98.2B 2B 00 00           (00)
Thu 09/11/2014 12:19:00 PM : [std-Direct Ack] 25.89.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
In the admin console click on the red togglelinc text under the scene name.  This will show the responder options for the scene when controlled by the togglelinc.  Make sure this matches the scene responses that are listed when you click on the scene name (if that is what you want).
E
The pic is for the responders of the togglelinc and appears correct.  Unfortunately I cannot help with the test results.  Hopefully someone will chime in.  What is the load for the devices, meaning what type of bulbs.  Do you have the legs of your electrical system bridged.
Took my cell phone on TeamViewer and watched the ISY console when I manually switched the togglelinc controller.  Turns out for some reason ISY was not updating its state from "off" to "on" and vice versa after a manual switch.  This was the case even though there were no reported communications problems - i.e., I could turn the togglelinc device on and off from the console.  A simple restore device for both controller and responder solved the problem.  Should have tried that before posting, but thanks to all for the help.
      377.2k
