Disabling retriggers
For the purpose of this illustration I will use the multiple Notifications problem, being a common one for many, but this could apply to any response taken from an event trigger where repeated actions could be an unwanted effect.
A common method of avoiding multiple notifications is to have a second disabled program disable the first, and triggering, program for a set amount of time.
Program.1
    water_leak_detected
    run program.2
Program.2
    disable Program1
    send notification "we got leaks!"
    wait 1 hour
    enable Program.1
Can anyone see a problem with using only a single program (below) to do this same thing?
The program would already be triggered and disabling it would not stop it's progress.
Could this be caught in a power failure and lock out as disabled?
Program
    water_leak_detected
    disable Program
    wait 1 hour
    enable Program
Thoughts?
Unfortunately Disabling the running Program stops the Program.  The statement after the Disable executes but that is all.
Program AAA2
        Control 'SwitchLinc Dimmer DB' is switched On
        Disable Program 'AAA2'
        Send X10 'A5/On (3)'
        Wait  5 seconds
        Send X10 'A6/On (3)'
        Wait  5 seconds
        Send X10 'A7/On (3)'
        Wait  5 seconds
        Send X10 'A8/On (3)'
        Enable Program 'AAA2'
Mon 09/15/2014 11:23:57 AM : [iNST-SRX    ] 02 50 1D.23.6B 00.00.01 CB 11 00    LTONRR (00)
Mon 09/15/2014 11:23:57 AM : [std-Group   ] 1D.23.6B-->Group=1, Max Hops=3, Hops Left=2
Mon 09/15/2014 11:23:57 AM : [D2D EVENT   ] Event [1D 23 6B 1] [DON] [0] uom=0 prec=-1
Mon 09/15/2014 11:23:57 AM : [  1D 23 6B 1]      DON   0
Mon 09/15/2014 11:23:57 AM : [D2D-CMP 0042] CTL [1D 23 6B 1] DON op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Mon 09/15/2014 11:23:57 AM : [D2D-CMP 0013] CTL [1D 23 6B 1] DON op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Mon 09/15/2014 11:23:57 AM : [iNST-SRX    ] 02 50 1D.23.6B 22.80.0B 41 11 01    LTONRR (01)
Mon 09/15/2014 11:23:57 AM : [std-Cleanup ] 1D.23.6B-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Mon 09/15/2014 11:23:57 AM : [iNST-DUP    ] Previous message ignored.
Mon 09/15/2014 11:23:57 AM : [D2D EVENT   ] Event [1D 23 6B 1] [sT] [102] uom=0 prec=-1
Mon 09/15/2014 11:23:57 AM : [  1D 23 6B 1]       ST 102
Mon 09/15/2014 11:23:57 AM : [X10-RSP     ] 02 63 61 00 06
Mon 09/15/2014 11:23:57 AM : [D2D-CMP 002B] STS [1D 23 6B 1] ST op=1 Event(val=102 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Mon 09/15/2014 11:23:57 AM : [        Time] 11:24:00 2(0)
Mon 09/15/2014 11:23:57 AM : [         X10]       A5
Mon 09/15/2014 11:23:57 AM : [         X10]       A5/On (3)
Mon 09/15/2014 11:23:58 AM : [X10-RSP     ] 02 63 62 80 06
Mon 09/15/2014 11:23:59 AM : [X10-RX      ] 02 52 61 00
Mon 09/15/2014 11:23:59 AM : [         X10]       A5
Reduce your Wait from 1 hour to 30 seconds.  The Program will not Enable itself.
Program AAA2
<big snippage>
Thanks LeeG. That's what I was looking for!
Your event reading skills are invaluable here. (jealous) I haven't spent the time to learn that, which is unlike my usual behaviour.
Why learn? I've added the LeeG module (1$). SUCH a great investment! :P
Edited by ravedog
