MikeD Posted October 3, 2014 Share Posted October 3, 2014 I have a Trane TZ400BB3VZNNSL Z-Wave thermostat, which is basically the same as a RCS TZ45. Fan Modes available for selection on the thermostat itself are Auto, On and Cycle. Could you please add the option for Cycle Fan to the Fan Mode selection? When the thermostat is set to Cycle Fan mode the ISY Admin Console displays the Fan Mode as Auto High. The command http://ISYADDR/rest/nodes/ZW###_1/set/CLIFS/2 will set the thermostat to Cycle Fan mode. Thanks ~Mike Link to comment
Mike Ippolito Posted October 4, 2014 Share Posted October 4, 2014 Quick update, we've been discussing this internally and it appears that model uses /2 for cycle but the standard is /6 to set cycle mode. We're investigating ways to support this and will get back to you. Link to comment
Mike Ippolito Posted October 4, 2014 Share Posted October 4, 2014 Sorry, one more question, what firmware is the thermostat on? To get firmware, pull it off the base and then snap it back in (power cycle) it will report firmware upon boot. Link to comment
MikeD Posted October 4, 2014 Author Share Posted October 4, 2014 Hi Mike, Firmware version is 01.01.40 Also I see the correct model number listed on this screen is TZEMT400BB32. I originally posted what I ordered from the vendor. ~Mike Link to comment
danbutter Posted August 16, 2016 Share Posted August 16, 2016 I know this is old, but I'm in the same boat with a clone of this thermostat. I have the evolve T100R on version 02.02.36. I'm running 5.0.2 right now and would love to be able to choose the circulate option without being in front of it. Link to comment
Chris Jahn Posted August 16, 2016 Share Posted August 16, 2016 I know this is old, but I'm in the same boat with a clone of this thermostat. I have the evolve T100R on version 02.02.36. I'm running 5.0.2 right now and would love to be able to choose the circulate option without being in front of it. A Z-Wave thermostat reports all of the modes/fan modes etc. that it supports. It may be that it is just incorrectly reporting the wrong set of fan modes. I'll open a bug report to see if we can do something custom for this thermostat, or add a generic manual override feature of some sort. Not sure when this will be fixed though. Link to comment
PurdueGuy Posted August 16, 2016 Share Posted August 16, 2016 A Z-Wave thermostat reports all of the modes/fan modes etc. that it supports. It may be that it is just incorrectly reporting the wrong set of fan modes. I'll open a bug report to see if we can do something custom for this thermostat, or add a generic manual override feature of some sort. Not sure when this will be fixed though. Chris/Michel: Has there been any there (possibly further) discussion of adding the ability to send arbitrary Z-Wave data? For example, back when I ran things with my Vera, you could send data to a specific node. In this case, I could trigger the fan with the following: Fan: luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='<nodeID>',Data='68 1 <fanMode>'},1) <nodeID> is the Z-Wave Node ID <fanMode> can be: 0: auto 1: on 2: cycle I've seen references that you could also set "parameter 68" to the desired value, but I am not at home, and cannot try. Link to comment
danbutter Posted August 16, 2016 Share Posted August 16, 2016 Well I don't know if this helps, but it seems that the ISY is getting the info from the thermostat... the option to set it just isn't there.I'll see what I can find playing with the parameter 68. Oops..I guess the screenshot didn't attach properly using my tablet...take 2. Link to comment
MWareman Posted August 16, 2016 Share Posted August 16, 2016 Chris/Michel: Has there been any there (possibly further) discussion of adding the ability to send arbitrary Z-Wave data? For example, back when I ran things with my Vera, you could send data to a specific node. In this case, I could trigger the fan with the following: Fan: luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='<nodeID>',Data='68 1 <fanMode>'},1) <nodeID> is the Z-Wave Node ID <fanMode> can be: 0: auto 1: on 2: cycle I've seen references that you could also set "parameter 68" to the desired value, but I am not at home, and cannot try. That would be awesome if possible! Add my +1! Link to comment
Michel Kohanim Posted August 17, 2016 Share Posted August 17, 2016 Hello all, I would have to defer it to Chris. This said, and based on our history with INSTEON, I very much doubt we would allow this simply because changes made to Z-Wave nodes are captured and religiously synched with actual Z-Wave device configuration. Allowing this basically means that any type of backup and restore will be meaningless as ISY would probably never know what has been done to a device. With kind regards, Michel Link to comment
danbutter Posted August 20, 2016 Share Posted August 20, 2016 I did try to play with parameter 68, but nothing happened. Link to comment
PurdueGuy Posted August 20, 2016 Share Posted August 20, 2016 I did try to play with parameter 68, but nothing happened. I am not surprised. I didn't think it was actually a parameter, it's more like a command type. But couldn't hurt to try! Thanks! Link to comment
