Portal maintenance - October 2 - 4am-5am Pacific ×
2441TH Cuurent State Update
Waketech
I just installed the 2441TH and noticed the temp in "Current State" does not update unless I manually query it
1. Am I just impatient, is there a default refresh time ?
2. Is this device capable of auto updating ?
It should update anytime there's a change in temperature. Try blowing some hot air on the device, you should then get a update.
Techman,
It seems that the current state temp only updates when the device is queried on the ISY, the temp on the thermostat updates in real time.
Hi Waketech,
Are you certain this is not a ZTH .. if so - and if on battery - this is normal.
Otherwise, please check the number of links in your PLM: for INSTEON devices to report their status, there must be a link in the PLM and if you reach 800 or more, then you will not get any status updates.
Hi Waketech,
Mike,
Definitely not the wireless one, for the links please confirm I did this correct
Tools > Diagnostics > Show Device Links Table > Chose the thermostat and left the check box unchecked.
The response I got was....
0: 1FF8:E2 EF 2A.A2.1E 01 00 EF
1: 1FF0:E2 01 2A.A2.1E 01 00 01
2: 1FE8:E2 02 2A.A2.1E 01 00 02
3: 1FE0:00 00 00.00.00 00 00 00
count = 4
Does your humidity update regularly?
I will check tonight as well as completing a factory reset as mentioned in the other post
Posted (edited)
Reset and no updates come in on the event viewer for temp or humidty
Hi WakeTech,
Please also check the number of links in the PLM (Tools | Diagnostics | Show PLM Link Table) and then click on the Count button.
Mike, count is 22
Edited by Waketech
Hi Mike,
That's the issue (very low link count). Now, please remove the thermostat from ISY and then link it back in. If you do get events, then it means that the PLM has lost its links.
Have you recently changed PLMs? If so, have you already done File | Restore Modem or File | Restore Devices?
Posted (edited)
Hi Mike,
Mike,  tried that and no the PLM has not been replaced.  I have this discussion going on another thread (sorry different question but lead to talking about this issues).  From what Xanthros is saying I think it may be that the only time the data will update from a query inside a program is when a variable actually changed, vs from the main menu it will always grab data ?
http://forum.universal-devices.com/topic/14100-2441th-two-wire-wo-power/page-2
Edited by Waketech
Hi Waketech,
Xathros is correct: in case of programs, the values are updated if and only if something changes.
This said, the original question was about the thermostat not sending status updates as they change. Has this been solved?
Posted (edited)
My contribution was to point out that the data received at 3am was likely due to the 3am query running.  This "Qurey All" is built into the ISY that runs by default at 3am.
Hi Waketech,
It was LeeG that pointed out that the data is only sent via program query when a value has changed.
Now, what need to be done:
1) Open the console, open the event viewer, set to level 3 (Device Communications)
2) Take a hair dryer and blow some warm air at the stat.
See if any traffic is recorded in the event viewer from the stat.
If not, back to checking link records.
I believe there is a specific procedure that needs to be followed when adding a TStat to the ISY.  As I recall, the stat needs to be in the "Off" mode when adding for all of the nodes to be correctly added.
-Xathros
Edited by Xathros
-Xathros
Perfect, will give this a shot tonight.
Thanks again
Sorry for the delay,
Last night I was doing some painting in the garage so at 8:44 pm I set the thermostat to turn on and warm the garage.  I came back in at 9:50 pm and the main page did not update anything (temp, set point humidity) when I manually queried everything matched the local display of the TSTAT.  Unfortunately I did not look at the comms log (I will do this tonight, same test).  On a side note If I run a program to auto query at an interval of xxxx min  that seems to work just fine (TSTAT gets updated when queried, only if there is data to update).
  • 1 month later...
Not sure what happened here.  I had a different issue with my 2441th unit entering "energy mode" and so I replaced it with a newer one with more recent firmware (10 vs 0D).  I am no longer getting temperature change reading updates like I used to.  Not sure if this is due to firmware or something else.  When I query the unit, it says the right temperature.
  • 6 months later...
Hate to revive an old thread, but I find myself in this same situation and would really like to solve it.
ISY994i/IR Pro with firmware 4.2.30
2441TH v.0B Thermostat
215 PLM links (I see two for the thermostat itself)
As others were noting, when querying the thermostat, it will return the proper temperature. I'll try watching device communication later today to see if the thermostat is sending any communications when the temperature changes.
      38.2k
      380.8k
