Upgrade ISY994i IR/Pro to Zigbee
mrbudin
Dear friends,
Can i make my ISY 994i IR/Pro work with some Zigbee  Door Lock or Zigbee Garage Door by upgrading to Zigbee module?
I am thinking of Z-Wave but still looking for a solution if it can work with Zigbee.
Regards,
  • 5 months later...
Just wondering what is "high" on the list, as zigbee devices are plenty and seem to be always cheaper....
So just courious what other innovations are in the works...
Hi GGITech,
Although Zigbee devices might be plenty, they are usually not interoperable. High on our list:
1. Program/Variable enhancements (done)
2. Virtual nodes (almost done)
3. Z-Wave enhancements  (next)
... High on our list:
Well that's a fine bit of news, sounds like 5.0 is moving right along... :)
Thanks Michel!
Hi GGITech,
Sweet! Looks like! variable enhancements may be in an early drop after all!
Michael can I ask what virtual nodes will allow us to do as a community (if anything)?
For example will virtual nodes let us take data from network resources and let us flag it as 'energy' or create support for devices that you don't support directly?  Or is there some other purpose to at a platform level that gives you flexibility to do more, more easily, later.
I don't mind what the answer is, just want to be clear on how I set my own expectations :-)
Hi Scyto,
Virtual nodes allow you to incorporate network nodes into ISY (so, you might not need network resources) and then use them in programs + be able to send them applicable commands. So, in essence, yes, you can have energy monitor nodes (have to be defined by you) and then Automation Shack or some other device (such as Brultech Dashbox) can publish events into those nodes.
Michel,
Will they work the other way as well?
For example. I define a virtual node to represent a url (a mostly complete GET request to Auto remote, with a single parameter to be replaced with the level, say 1-255). I then put that node into a scene (as a responder), with an 'on' level to match the other nodes in the scene.
Now, as the scene is called, Auto remote receives the messages with the on level. Bright and dim commands send the new level to the node etc etc......
Michael.
I suspect the reverse could be done with the substitution in network rules - so perhaps asking to be able to make a network rule a responder in a scene may be better. Just a thought...
      377k
