4-way switch
Jay M
In my dining room I have a chandelier and I have 3 switches that need to control it:
1. the actual load bearing switchlink dimmer
2. a secondary switchlink dimmer where the old 3-way secondary was
3. A keypadlink letter
I may be off on the wrong track, but here's what I did...
Created a scene call dining room light
added the two switchlinks and the letter G from the keypad
It is very close to working but here is what it does:
When I turn on the light from either the kaypad or the secondary all the LEDs do what I would expect the "G" turns on and both switchlinks show the dim level.
But when I use the load bearing switchlink the other two devices' LEDs don't respond. This is particualr annoying because the G button is a toggle.
What did I do wrong?
thanks,
~Jay
I guess I don't really understand what is a controller and what is a responder, and when to use them.
As far as I know I did add it as a responder. Should it be a controller?
Is it possible to change it, or do I need to remove it and re-add it?
thanks,
~Jay
Hello Jay M,
Yes, all should be controllers (they are controlling one another). And, yes, unfortunately you will have to remove and then add them back in.
thanks,
~Jay
      38.2k
      381.1k
