error log question
Hi richardl007,
This means:
-110014 SD DRIVE CONFIG READ FAILED
You will find all our error codes listed here:
http://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Errors_And_Error_Messages
What it basically means is that ISY has a problem reading the configuration file for your INSTEON device with address of "12 EF AE".
Two things may contribute to this issue:
1. Corrupted SD Card
2. Corrupted file
The first question is: what is this device? If still in your ISY, you may want to remove it, and then add it back.
The second question is: do you have more of these errors with other files? If so, then I suspect you have a corrupted SD card
Cloud you help me with these as well?
System -5 Start
Thu 2014/11/13 07:57:40 PM System -170001 [Network] Established
Thu 2014/11/13 08:07:53 PM System -170001 [uDSockets] RSub:28 error:6
Thu 2014/11/13 08:07:58 PM System -170001 [uDSockets] RSub:28 error:6
Thu 2014/11/13 08:08:03 PM System -170001 [uDSockets] RSub:28 error:6
Thu 2014/11/13 08:08:06 PM System -5012 28
Thu 2014/11/13 08:36:54 PM System -5012 29
Thu 2014/11/13 08:37:17 PM System -5006 uuid:29
Thu 2014/11/13 08:39:15 PM System -5012 30
Thu 2014/11/13 08:42:02 PM System -170001 [uDSockets] RSub:27 error:6
Thu 2014/11/13 08:42:05 PM System -5012 31
Thu 2014/11/13 08:47:17 PM System -170001 [uDSockets] RSub:27 error:6
Thu 2014/11/13 08:47:19 PM System -5012 32
Thu 2014/11/13 09:02:37 PM System -5012 33
Thu 2014/11/13 09:03:33 PM System -170001 [uDSockets] RSub:31 error:6
Thu 2014/11/13 09:03:38 PM System -170001 [uDSockets] RSub:31 error:6
Thu 2014/11/13 09:03:40 PM System -5012 34
Thu 2014/11/13 09:10:35 PM System -5012 35
Thu 2014/11/13 09:14:24 PM System -5012 36
Thu 2014/11/13 09:14:56 PM System -5012 38
Thu 2014/11/13 09:14:57 PM System -5006 uuid:38
Thu 2014/11/13 09:17:40 PM System -170001 [uDSockets] RSub:27 error:6
