Bathroom light night light
Hi
I have searched the forum for info but can't find any Info, I want to have my bathroom light come on to 30 % between 11 PM and 5 AM when it is switched on, but 100 % any other time.
 the program I have is simple, If between 11 pm and 5am the next day and bathroom light is switched on
then set bathroom light to 30 %
It workes but after the time frame it still goes to 30 % untill it is by passed with a fast on then the rest of the day it works, any way around this ? I'ved a few different things with same result
Thanks for any help
Jeff
If using a SwitchLinc check the SwitchLinc User Guide around page 10-12 (depends on SwitchLinc version) for the discussion on Local On Level "Resume Bight". The SwitchLinc can be set to two options, one is to use the last On Level (Resume Bright) or use a fixed Local On Level.
Also note that the ISY Program "Adjust Scene" statement can be used to establish the Local On Level using the same time bracket. The Program uses the Adjust Scene to establish a Local On Level at 11PM and another Local On Level at 5AM. The SwitchLinc reacts to these Local On Levels without further Program involvement so the load comes on to the desired On Level without any delay related to triggering a Program.
