how to get dusk & logs to work on new ISY-994i
jim_
Hi, just purchased an ISY-994i to replace an X10 system from the 90’s running on a DOS controller
This type of programming is completely new to me, so what may be obvious to others is something I am struggling to understand.
I am using 2 lamp modules to test with and mixing in some existing Leviton control switches … this is my test program which does not trigger at DUSK.
IF –         Program ‘Dusk’ is True
Then –   Set Module_1 On
               Wait 10 seconds
               Set Module_2 On
               Send X10 ‘C1/On (3)’   <<< Leviton control switch
Else -     Set Module_1 Off
               Set Module_2 Off
Nothing happens when the Sunrise/Sunset time surpasses the Sunset time ?
Next,
there are no Diagnostic / Event Logs being generated … how do you enable them ?
Check that the Sunrise does not say (same day).   It should be set to (next day).  Post the actual Program (right click on Program name and select last option Copy to Clipboard).   Paste into forum post.
Wrong
        From    Sunset
        To      Sunrise (same day)
Right
        From    Sunset
        To      Sunrise (next day)
Edited by LeeG
        From    Sunset
won't do anything unless there is another trigger condition.
        Time is Sunset (or Sunrise)
will be true at that particular time. No other conditions are needed.
Does the Then not trigger at Sunset and Else trigger at Sunrise?
        From    Sunset
Edited by LeeG
Thanks for the info, but here comes the questions on editing
Editing the program, the first pull down in the If condition window only has "And" & "Or" to select
How do I get a pull down to select "From" & "To" ?
Cheers
Thanks for the help, got it working
What is the DUSK program for / do ?
        Program 'Dusk' is True
stusviews, on 07 Dec 2014 - 9:43 PM, said:
What "DUSK" program?
forget it ... I see my error
Edited by jim_
        From    Sunset
What?
I have to disagree.  I believe this will trigger and run then at sunset and trigger and run else at sunrise.
Edited by Xathros
That's good to know. One program for both dusk and dawn. Thanks.
      380.1k
