Teken Posted December 9, 2014 Posted December 9, 2014 There is a current KS project under way for a new two piece system that can monitor the flow of water, temperature, humidity, and also open / close the main water line.This device does NOT require any plumber or cutting of the water pipe. It is the closest thing to plug and play I have ever seen in the market. Many of us have tried very hard to integrate the water monitoring into our system. This new product if its funded will help us get there.You can show your support and get one cheaper now if you enlist now: https://www.kickstar...d-c/descriptionI was lucky enough to sign up as a Beta tester so I can help shape and mold this product to its full potential. I hope this provides a solution for those like me who want to measure and record the water flow.
stusviews Posted December 9, 2014 Posted December 9, 2014 I'm not aware of any crowdfunding home automation product that has come to fruition.
io_guy Posted December 9, 2014 Posted December 9, 2014 I'll sign up for this. Teken, if they're taking beta feedback, I'd love to see... - Support for Pex lines if it doesn't already - Direct access support (no cloud) - Feedback on valve position
Teken Posted December 9, 2014 Author Posted December 9, 2014 I'll sign up for this. Teken, if they're taking beta feedback, I'd love to see... - Support for Pex lines if it doesn't already - Direct access support (no cloud) - Feedback on valve position The device works either PEX / Copper. Keeping in mind this is literally a plug and play a fair. Every water system would have a transition from copper to PEX where the main line enters and to the actual meter. The reading sensor just straps to the side and reads the magnet flux of the internal magnet to determine the amount of revolution from that little spinner dial. I have already asked they have a direct access API from the cloud, make it 3rd party friendly, and also have a 5 volt pulse output so it can be used in other devices. The system will tell you open / close and allow you to remote open, schedule, set limits already. Encrypted By: Phoenix Security Solutions
Teken Posted December 9, 2014 Author Posted December 9, 2014 I'm not aware of any crowdfunding home automation product that has come to fruition. Lots of them completed the funding, pledges, whether they sold more afterwards is unknown. Most are sold online in house it use online presence like Amazon. Which by default would make it market ready. Encrypted By: Phoenix Security Solutions
Teken Posted December 9, 2014 Author Posted December 9, 2014 For example... Your looking for a list of companies that have completed the KS funding and mailed out their rewards? Or those that continue to be in business selling their wares after the KS program? The most famous is the Pebble watch a close second would probably be the UBI.
io_guy Posted December 9, 2014 Posted December 9, 2014 Every water system would have a transition from copper to PEX where the main line enters and to the actual meter. My house is Pex right out of the concrete and through my main ball valve. I have already asked they have a direct access API from the cloud, make it 3rd party friendly, and also have a 5 volt pulse output so it can be used in other devices. What about local API? I have zero desire to link my water valve to the cloud.
Teken Posted December 9, 2014 Author Posted December 9, 2014 My house is Pex right out of the concrete and through my main ball valve. What about local API? I have zero desire to link my water valve to the cloud. Unsure, but have posed those questions to the creator and hope these questions and requirements can be done. I stressed its great that the information is in the cloud but many of us want direct control over our data and have the ability to manage and push / pull it to other services / devices.
paulbates Posted December 9, 2014 Posted December 9, 2014 There is a current KS project under way for a new two piece system that can monitor the flow of water, temperature, humidity, and also open / close the main water line. Thanks for the heads up Teken, very interesting. My house is Pex right out of the concrete and through my main ball valve. What about local API? I have zero desire to link my water valve to the cloud. Are you thinking H20Link? If it were possible, what a welcome addition to the shack family that would be! While I can only use the watermeter portion, I would love to know my water usage, especially as sprinkler runtimes are tweaked. Then, have usage data sent to syslog on a regular basis. Teken, do let us know what they say about local api access. Thanks!
JSP0511 Posted December 9, 2014 Posted December 9, 2014 I may take a crack at this! I'd love the ability to integrate water hero with Insteon leak sensors. Sent from my iPhone using Tapatalk
Teken Posted December 9, 2014 Author Posted December 9, 2014 Thanks for the heads up Teken, very interesting. Are you thinking H20Link? If it were possible, what a welcome addition to the shack family that would be! While I can only use the watermeter portion, I would love to know my water usage, especially as sprinkler runtimes are tweaked. Then, have usage data sent to syslog on a regular basis. Teken, do let us know what they say about local api access. Thanks! How come you can't use he sensor portion it just straps on? Unless you're on a well or the meter is actually not accessible? I hope to see more information about the API access. Remember, for those interested you can purchase just the sensor which reads the water consumption, temp, humidity, and records all the information which can send alerts etc. The actual shut off valve is just the second part which only make sense if there was a leak the system could turn on / off the valve remotely or based on threshold / schedule. What I like about this system is there is no cutting involved just strap it on and plug and play.
paulbates Posted December 9, 2014 Posted December 9, 2014 Teken, I can't use the valve control portion, I have old style twists that are 50+ years old and I am afraid to touch them . I can use the strap on meter part, thats what I meant.
JSP0511 Posted December 9, 2014 Posted December 9, 2014 Ok got in for $119 but damn, October 2015!?!? Sent from my iPhone using Tapatalk
Teken Posted December 9, 2014 Author Posted December 9, 2014 Teken, I can't use the valve control portion, I have old style twists that are 50+ years old and I am afraid to touch them . I can use the strap on meter part, thats what I meant. Well, in the big picture you're going to be able to see more information about the flow, consumption, temp, humidity, freeze, and track the stats. Ok got in for $119 but damn, October 2015!?!? Sent from my iPhone using Tapatalk Yeah, that is why I was on the Beta program because I didn't have such a long lead time!
JSP0511 Posted December 9, 2014 Posted December 9, 2014 This is great because a powered valve for 1 1/4" copper pipe is about $500 just for the valve Sent from my iPhone using Tapatalk
Teken Posted December 10, 2014 Author Posted December 10, 2014 This is great because a powered valve for 1 1/4" copper pipe is about $500 just for the valve Sent from my iPhone using Tapatalk Make sure you get in so this project goes through and spread the word to all you. Encrypted By: Phoenix Security Solutions
Methos000 Posted December 11, 2014 Posted December 11, 2014 This is pretty cool, i'm in for an early backer!
Teken Posted December 11, 2014 Author Posted December 11, 2014 This is pretty cool, i'm in for an early backer! That's great to hear and please do spread the word via Face Book, Twitter, or any other forums you're a member of. I am currently in talks with the Dev team and have a few personal phone calls waiting for confirmation. I provided a list of wants and requirements and expressed *OUR* views about the dependency of the cloud. They have been pretty receptive so far but stated some elements may increase costs which they are trying to avoid because the system was intended to be low price when compared to competing products out there. I really stressed having a open API for third party Dev's and integration to other devices / services. It was also indicated the importance of having surge protection to protect the final product. And having a direct port to the water pulse output as this would help guys like me who have a GEM which records water / gas pulses which can then be recorded for historic recall later. The final piece was stressing the importance of their privacy & security policy. I stressed my information should not be sold, leased, relayed, to anyone with out my consent. I have been very impressed with both KS vendors in letting me give my $0.02 cents thus far. If those see the benefit in this project please do sign up and show your support. Mention you saw this here at the UDI site and from Teken.
Teken Posted December 11, 2014 Author Posted December 11, 2014 I just received a personal invitation for a teleconference at 7:00 CST my time with the engineers and Dev team. If there are specific questions about the API and how it should operate please post them here. As that area is not my strong suite so any specific questions write them out in plain English so I can pose them. Once again I thank each and every one of you who decided to take a chance in helping this fine company bring this fantastic device to market. I know for me having a hand in developing this product is outstanding!
io_guy Posted December 11, 2014 Posted December 11, 2014 Local API is a must, don't care how it's implemented: - Setup commands in the unit to send REST to an IP address - Socket subscription - Polling for status Don't care. Need a way to get value and sensor status and to control the valve
paulbates Posted December 11, 2014 Posted December 11, 2014 +1 This is the same appeal of the Venstar T5800/T5900, both cloud and local lan access. Local LAN access via REST commands is needed and will make integration with the ISY meaningful Sent from my iPad using Tapatalk HD
Teken Posted December 11, 2014 Author Posted December 11, 2014 Local API is a must, don't care how it's implemented: - Setup commands in the unit to send REST to an IP address - Socket subscription - Polling for status Don't care. Need a way to get value and sensor status and to control the valve +1 This is the same appeal of the Venstar T5800/T5900, both cloud and local lan access. Local LAN access via REST commands is needed and will make integration with the ISY meaningful Sent from my iPad using Tapatalk HD Understood and will forward the same to the team this evening.
Teken Posted December 12, 2014 Author Posted December 12, 2014 I just got off the phone with the team and have to say the conversation was outstanding! I have asked the creator to chime in and provide the details of what was said and what the future may hold. From a consumer point of view I would like to relay my thoughts and impressions with those I spoke with. They are eager, open, and willing to listen to all views and consider others. I believe they have a winning product that is literally first of its kind where it is plug and play with out the hassle of cutting any pipe. My feelings are this product will render a viable solution for those wanting to know more about their water consumption. All the while providing extra capabilities of opening / closing the main water line. For now, I look forward to our next conference call and hope the ongoing feed back will bring a first rate product that I know has huge potential for all.
