Different Times for Off on Friday/Saturday
I would like to turn a light on at Sunset, and turn off at 11PM on weekdays (Sun-Thu), and at 12:30AM for Friday and Saturday:
   On Sun, Mon, Tue, Wed, Thu
   From Sunset
   To 11:00:00PM (same day)
Or On Sat, Fri
   From Sunset
   To 12:30:00AM (next day)
   Send X10 H11/On
   Send X10 H11/Off
Is my logic correct? It ran and turned on the lights this weekend, but didn't turn them on tonight (Sunday).
I know the first question is did I have X10 issues? I'm sure that is not a problem, as in the summary screen on the console the program did not run at sunset.
jrabin,
I think you would want to do the following:
       Time is Sunset
       Send X10 'H11/On'
   On Mon, Tue, Wed, Thu, Fri
   at 11:00 PM
   Or
   On Sat, Sun
   at 12:30 AM
   Send X10 H11/Off
   From Sunset
Or On Sat, Fri
   From Sunset
   Send X10 H11/On
   Send X10 H11/Off
   From Sunset
Or On Sat, Fri
   From Sunset
   Send X10 H11/On
   Send X10 H11/Off
Your logic is correct; if it is not working it is because of a bug. I'll try to reproduce the problem here, but in the meantime it looks like Michel posted a workaround for you.
I think you will find it's a bug. I'm running your 2.6.7 beta.
jrabin,
I tested your program and a bunch of similiar programs and could not reproduce the problem. There must be something else going on because after taking a closer look at the code, if these programs didn't work then nobodys schedules would be working.
Is it possible your program is in a Folder with Folder conditions?
