Any reason to upgrade from firmware 2.6.3?
I have firmware 2.6.3 is there any reason to upgrade to a higher version? All is working fine now for months.
Ray
If all is working fine, then there is no hurry to upgrade. If you want the new features, then you will want to upgrade.
I just found a reason to upgrade"
"Fixes in 2.6.4
Replace Device used to change the device type to Icon LampLinc"
I just ran into this after replacing old switches It messed up the device type and the controls for on/off etc.. were missing from my screen. I had to remove it from my lighting and then re link/add the device then assign it to the appropriate sceens. Only 3 did this out of 8 replacements.
What will be the next firmware revision and when will it be available? Should I upgrade to a higher version in the meantime? 2.6.4? 2.6.5....
Ray
2.6.8 is currenlty in testing and 2.6.7 is currenlty available for download.
