January 31, 201511 yr I am getting the following java error when trying to access the admin console through web. Tried replacing java with it's latest version but still getting this error. Java Plug-in 11.31.2.13Using JRE version 1.8.0_31-b13 Java HotSpot Client VMUser home directory = C:\Users\SimSom----------------------------------------------------c: clear console windowf: finalize objects on finalization queueg: garbage collecth: display this help messagel: dump classloader listm: print memory usageo: trigger loggingq: hide consoler: reload policy configurations: dump system and deployment propertiest: dump thread listv: dump thread stackx: clear classloader cache0-5: set trace level to <n>---------------------------------------------------- Kindly advise. Thanks...
January 31, 201511 yr Open the Java Control panel (javacpl), select Security, edit Site List and add the IST IP address plus port.
January 31, 201511 yr Author Thanks stusviews. Unfortunately, still having same issue. Any other suggestions??
January 31, 201511 yr Did you clear your java cache including deleting installed applications and applets?
February 1, 201511 yr Hello rkhakhar, There are no errors as far as I can see. As Techman suggested, please clear your Java cache and then retry. If you are still having problems, please don't hesitate to contact our tech support team (links below). With kind regards, Michel
