Non-toggle KPL light stays on?
Hi everyone, I'm trying to do a KPL button that is called "Evening Scene" which turns off some lights, sets others to 40%, 20% etc.  When I used Indigo, I'd set the button to non-toggle ON.  The KPL would stay off, and when I press it, it flashes 2 or 3 times and the scene starts then the button goes off.  Using the ISY though the KPL light never turns off, it flashes 2 or 3 times but stays on.  It's not the off level backlight, it's fully on as in the same way the button beside it which is toggle looks.
Is that normal and would I make a scene with that button as the responder, and then say if that button is pressed, wait 1 second type thing and then turn it off?  Or should it always go off?
That is the expected KPL action for non-toggle On mode.   Triggering a Program that turns the button Off is one approach.  The other approach is to use non-toggle Off mode which triggers a Program that issues a Set Scene On for the Scene that now has the KPL button as a Controller.  That way the KPL button blinks twice and turns Off.  The possible issue is the slight delay in triggering a Program to turn the Scene On.  If no delay is wanted use approach 1 that triggers a Program to turn the KPL button Off is best.
Great thanks just wanted to make sure.  Probably a program that turns it off is easiest right now, although I don't mind if there is delay.  Just wanted to make sure it was acting as expected.
