March 17, 201511 yr I have successfully installed the Schlage BE469 Lock in my ISY network. On earlier installs of this lock for other clients I have notice that in the ISY admin console there was an "Options" button to select that would allow me to configure certain functions for the lock. With that in mind, I am trying to figure out why the "Options" button is not showing up on my setup. The only buttons I have are the ?"Query" "Lock" and "Unlock". Any suggestions as to why the "Options" button isn't showing up? I have upgraded my firmware thinking that this would help but it didnt.
March 17, 201511 yr Which ISY version? There are more that half a dozen available upgrades. Which Z-Wave version?
March 17, 201511 yr Author ISY994ir/Pro with zwave module. Zwave version 4.55. ISY Firmware = 4.2.28RC
March 17, 201511 yr Check to make sure the UI version matches the firmware version. Sent from my Nexus 7 using Tapatalk
March 17, 201511 yr Author Not sure what happened to my ISY but it is not responding to anything now. The IP address is no longer listed in my devices on my router and a reboot, refresh of the ISY, PLM or Router did anything. My ISY is now showing 3 solid blue lights and a flashing red one. With that in mind, when I get the ISY back online, how do I check for the UI version? Also, any suggestions on what might be wrong with my ISY would be appreciated.
March 17, 201511 yr Only Error light blinking: ISY cannot communicate with the SD Card. Please ensure: The micro SD Card (on the front) is seated properly. Unplug ISY, remove the rubber cap, using a sharp object, push the micro SD Card in so that it pops out. Push it back in so it clicks in. Apply power to ISY If reseating the micro SD Card does not work, you probably have a defective SD Card. Please consult Replacing/Formatting SD Card -Xathros
March 18, 201511 yr Author Xanthros, Yep... the sd card was the culprit. Changed it out for a new and everything is back the way it was. Thank you for all your help.
March 18, 201511 yr Happy to help. Glad you got it going. -Xathros Sent from my iPhone using Tapatalk
