AT&T to end email-to-text ×
Unknown error code(s)
In reviewing my error log, I'm receiving a string of entries citing error codes (-170001, -10108, and -100) not listed in my 4.2.8 user manual. Does anyone know what they mean and whether I need to change something to avoid the error log entries?
Tue 2015/03/17 04:26:33 AM System -100 [DHCP] state=RENEW     Tue 2015/03/17 07:24:35 AM System -170001 [Auth:-10104] 192.168.1.1:45530->80, Num=3 Tue 2015/03/17 07:24:35 AM System -170001 [Auth:-10104] 192.168.1.1:50664->80, Num=4 Tue 2015/03/17 08:26:45 AM System -170001 [Auth:-10104] 192.168.1.1:43357->80, Num=3 Tue 2015/03/17 08:26:45 AM System -170001 [Auth:-10104] 192.168.1.1:35051->80, Num=4 Tue 2015/03/17 11:24:37 AM System -170001 [Auth:-10104] 192.168.1.1:49214->80, Num=5 Tue 2015/03/17 11:24:37 AM System -170001 [Auth:-10104] 192.168.1.1:34714->80, Num=6 Tue 2015/03/17 11:24:37 AM System -10108 Check log         Tue 2015/03/17 12:06:16 PM System -170001 [Auth:-10104] 192.168.1.1:47557->80, Num=7 Tue 2015/03/17 12:06:16 PM System -10108 Check log         Tue 2015/03/17 12:06:16 PM System -170001 [Auth:-10104] 192.168.1.1:60417->80, Num=8 Tue 2015/03/17 12:06:16 PM System -10108 Check log         Tue 2015/03/17 12:06:16 PM System -170001 [Auth:-10104] 192.168.1.1:46090->80, Num=9 Tue 2015/03/17 12:06:16 PM System -10108 Check log         Tue 2015/03/17 12:06:16 PM System -170001 [Auth:-10104] 192.168.1.1:47732->80, Num=10 Tue 2015/03/17 12:06:16 PM System -10108 Check log         Tue 2015/03/17 03:06:42 PM System -100 [DHCP] state=RENEW     Tue 2015/03/17 03:16:47 PM System -170001 [Auth:-10104] 192.168.1.1:60130->80, Num=11 Tue 2015/03/17 03:16:47 PM System -10108 Check log         Tue 2015/03/17 03:16:47 PM System -170001 [Auth:-10104] 192.168.1.1:48771->80, Num=12 Tue 2015/03/17 03:16:47 PM System -10108 Check log         Tue 2015/03/17 03:16:47 PM System -170001 [Auth:-10104] 192.168.1.1:45428->80, Num=13 Tue 2015/03/17 03:16:47 PM System -10108 Check log         Tue 2015/03/17 03:16:47 PM System -170001 [Auth:-10104] 192.168.1.1:48422->80, Num=14
Hi erniekraut,
Error codes are listed here:
http://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Errors_And_Error_Messages
-170001 are informational messages.
-10108 means that someone is trying to login to your ISY using the wrong credentials ... the IP is 192.168.1.1
It t seems that your router keeps trying to login to ISY!
I had that when my DD-WRT WiFi proximity script had a typo in my username for the ISY.
-Xathros
