Expose scenes to secondary controller
Hello,
I just purchased a ISY994i-Zw and created some scenes for my inteon switches.
I also have some ZWave switches, I have added them to ISY successfully.
I have a secondary controller (Simon XT from Frontpoint), when I added the Simon XT to my network it picked up all my zwave devices without a problem.
My question is would it be possible to expose scenes from ISY to the Simon XT (maybe as a separate node of some sort) so that the simon xt could not only control the zwave devices but also the insteon ones ?
EDIT:
I guess what I am looking for is a zwave "virtual node " ?
Edited by sastie
hi sastie,
Unfortunately it's not possible since the command classes for Z-Wave are not anything like INSTEON and I am not so sure we can create any type of virtual Z-Wave node without going through certification for it. i.e. it has to act as a Z-Wave device.
Thanks for the answer.
Can ISY expose itself to another zwave controller as a device with simple on-off commands so that all items connected to the ISY receive said on-off commands?
What I am looking for is: my isy has my 15+ insteon devices connected to it along with zwave devices. When I leave my house I have a rule from alarm.com that is triggered by my simon xt to turn all lights off. Given that SimonXT only speaks zwave I was hoping that the ISY could pick this up and turn all my insteon devices off. My original question was attempting to make things on a per switch / scene addressable via virtual node to have more granularity, I  would be fine with a coarse approach.
Hi sastie,
Since Simon XT is a secondary controller, therefore if it controls your Z-Wave devices, ISY should pick up the status. So, if you use a device that reports its status (not those that you have to keep querying) and if you turn that device on/off from Simon XT, then ISY should be able to hear it. If this can be accomplished, you can have a program in ISY to do things based on the status of that device. I know AeoTec DSC06106 does report its status.
In short, instead of using virtual devices, you will need to use an actual device.
Thanks Michel,
Can Zwave controllers expose any functionality in Zwave ?
If so does ISY do any of that. or are there plans about supporting that feature (If this is allowed per Zwave spec)?
Forgive me if it is a stupid question, I have been on the insteon bandwagon for a long time and got into zwave last week...
  • 3 months later...
Hello,
EDIT:
Hi
Could you please explain how you added Simon XT to the ISY network?
Pardon for reviving an older thread.  I thought virtual nodes were a plan for 5.0.  Just Insteon?
How will ISY be able to bridge between Zwave and Insteon in a meaningful way?  Only by responding across protocols with programs?  Will we have scenes within the ISY that include multiple protocols?
Are there other devices that could create virtual zwave nodes that the ISY could recognize?  I see the spec supports virtual devices and have found reference to a bridge mode, but can't find a clear example of it implemented.  Looking for any way to reliably bridge the protocols to gain access to products like Wink Relay and Amazon Echo, but I want a solution that does not depend on a hack like the Echo/Hue bridge as I got burned once with time invested in setting up Siriproxy that was obsoleted before I got to enjoy it.
Hi ScottAvery,
I am little confused as what is requested and the relationship between virtual nodes, Wink, Echo, and Siri.
5.0 has support for virtual nodes but I doubt we'll be doing anything even remotely with Wink. We are working on Echo and we should have a portal based solution which will have nothing to do with virtual nodes.
