Mysterious ZWave Device Appeared - Energy Meter/Multi Sensor
I was adding two swtiches and noticed that there were two mysterious sensors that I did not add.
Energy Meter - Constantly showing 39.00 watts current power
Multi Sensor - Shows nothing today, but was showing a Temp which was +/- 1.1 degrees different than any of my other two sensors.
I have two AeoTec 4-n-1's online now.
The Energy Meter, when display options, shows exactly what one of the 4-n-1 shows.
(attached is the screen shot)
Multi Sensor shows nothing now.
Energy Meter = ZW006_143
Multi Sensor = ZW014_118
Not sure if that tells me anything, besides the order they were installed.
The other two 4-n-1's are reporting the data that they should report....
Any way to figure out what these are?
Troubleshoot what they are tied to?
I could delete a 4-n-1 but then I'd have to fix all my events and programs related to that sensor....
I think it is related to the "Guest Bath" 4-n-1 but for the life of me can't figure why the Energy Meeter popped up....
Strangely enough, the Bath 4n1 shows "general purpose" of 0.00, and the "hall" does not.
Same sensors, bought at same time, same firmware loaded.
Any ideas would be appreciated.
Edited by GGITech
Please post the results of the log when you right click on those two devices and select zwave show all in log.
Sorry for brevity - posted using mobile Tapatalk
Mikeuid: I will do that ASAP.
Neighbors? Yeah, maybe, but doubtful that they pushed their device to pair it at the same time I told ISY to add new device....I could run the stasticts on that, but the outside chance is close to me having sex with a Super Model.....
Hmmm....Ok, now I have a new device again "ZW 006 Pulse Meter" Never even heard of that....
ZW 006 Pulse Meter = "Pulse Count" 118095876
Also the Guest Bath 4-n-1 now shows "Wind Direction" = 2686976.00Degrees
Wow....I think it is just maybe a funky AeoTech????
Post logs in a few.
Clear Log. Right Click on Energy Meter -> Z-Wave -> Show Information in Event Viewer -> All
ENERGY METER LOG
INSTEON Device Control Value Time User Log Type
Hall / Sensors / Hall Enviro Luminance 7.00 lux Sun 2015/04/26 10:03:03 PM System Log
Hall / Sensors / Hall Enviro Current Temperature 73.20 F Sun 2015/04/26 10:03:03 PM System Log
Show All Node Detai ZWave ZW006_143 Sun 2015/04/26 10:03:13 PM System Log
Guest Bath / Sensors / Guest Bath Enviro Current Temperature 70.70 F Sun 2015/04/26 10:03:15 PM System Log
MULTI SENSOR LOG
INSTEON Device Control Value Time User Log Type Show All Node Detai ZWave ZW014_118 Sun 2015/04/26 10:04:54 PM System Log
Clear log every time and then info on single device
ZW 006 Pulse Meter
INSTEON Device Control Value Time User Log Type Show All Node Detai ZWave ZW006_144 Sun 2015/04/26 10:06:13 PM System Log Guest Bath / Sensors / Guest Bath Enviro Luminance 5.00 lux Sun 2015/04/26 10:06:15 PM System Log
Guest Bath 4-n-1 (this was the inital device I added, which shows up as two devices, Enviro and Motion)
INSTEON Device Control Value Time User Log Type Guest Bath / Sensors / Guest Bath Enviro Luminance 0.00 lux Sun 2015/04/26 10:07:15 PM System Log Guest Bath / Sensors / Guest Bath Enviro Humidity 36% Sun 2015/04/26 10:07:15 PM System Log Guest Bath / Guest Bath Fan Off   Sun 2015/04/26 10:07:15 PM Program Log Show All Node Detai ZWave ZW006_118 Sun 2015/04/26 10:07:22 PM System Log
  • 2 months later...
I have been experiencing this same issue lately. I now have 14 of these device on my ISY. It only happens to Zwave device and show up days even weeks after the original device was added. All show as energy meters or multilevel sensors with the exception of one water meter. Some show empty windows while others show distance, velocity, volume or watts. None of which are related to what the original decive should be reporting. The only way to get rid of them is to readd the device but they return a few days later.
Hello Harvvm,
Z-Wave devices a) describe the types of alarms they send B) ISY makes a node for those events and c) when the event comes, ISY updates the status. The issue here is that some devices send alarms without describing it initially (during inclusion). So, ISY simply adds a nodes presuming that this alarms is a valid event and so that you can decide to remove it on your own. This is the root cause for any phantom nodes.
Thanks for the reply Michel. That explains it.
Harv
I have a couple of devices that seem prone to report phantom nodes. It sure would be nice if there was a config parameter on ISY to effectively prevent the auto-creation and throw away these spurious events....
Or, change the logic so that they are suppressed until some threshold, or prompt the user for confirmation before adding (specifically suppressing future events if the user says 'no').
It just gets a little old having to keep deleting the 'Water Sensor' that keeps showing up against my Aeotec smart switch.
5.x feature? ☺
Hi Michael,
Thank you. Does this report Water Sensor node? I have one of these at the office and have never seen a spurious node (yet).
Once I know exactly what node type it is, I will contact AeoTec and see whether or not they can  help us.
And, we will look into adding a feature to ignore some alarms.
Michel,
Of course if has happened for a few days. Once it does I'll let you know. I should reinforce - I have two of them right next to each other. Only one of them does this.
Michael.
Hi,
I'd also like to vote for a way to easily remove phantom nodes; while not ISy's fault, they sure are a nuisance.
I too, get repeated phantom nodes from BOTH an Aeotec Aeon Labs AEDSB09104ZWUS Aeotec Z-Wave Smart Energy Monitor, and the older Aeon Labs Aeotec Z-Wave Multi-Sensor (not the new six sensor).  Either one randomly grows a water sensor. Without "pruning" of these phantom devices, they show up in mobilinc, and generally clutter and distract - and they report nonsense values that change over time.
I hope you might implement something like MWareman's suggestion.  Even if ISY is just reporting what the sensor sends, a workaround to suppress these bogus messages/nodes would be helpful.
Thanks for the great ISY products and great ISY support.
Edited by whywork
  • 1 year later...
I also get phantom sensors (ZW 004) energy and pulse meters, after I installed an Aeotech 6-1 multisensory (new model).  It has the latest firmware as well (1.07)
Fixing this issue is enough to make me give 5.0.9 a whirl. Upgrading from 5.0.2. Wish me luck. :wink:
Thanks for the fix!!!
