Scene on before sunrise programming
Need some help with programs to run a scene(winter) from 6:30 to 7:30 before sunrise but if it is after sunrise I need scene(summer) to run from 6:30 to 7:30. Please excuse the wording I don't have the program in front of me
Program 1:
before sunrise -10 minutes
and
mon, tues, wed, thurs, fri
6:30 - 7:30
run scene winter
stop scene winter
Program 2:
after sunrise +10 minutes
and
6:30 - 7:30
run scene summer
stop scene summer
I know its simple but I can't get it to work any help would be appreciated. TIA
Since the syntax will be critical on this perhaps you can paste your programs here for the exact wording. Right click on the program's icon (in ISY's Admin Console) and select "copy to clipboard". Then paste it here.
One point of possible misunderstanding is the time conditions using sunrise do not have a before or after. They will trigger at an exact time specified only. Any event listed in your "If" section will cause the whole logic to be evaluated and run then or else depending on the outcome. At 7:30 on weekdays both "elses" will run.
I will have to post it later today when I have my laptop
Do the programs have to exactly at 6:30 and stop at 7:30? If so the determination of season using sunrise will cause problems in the same program. It appears to only ever start the "Then" sections based on your sunrise times. At 6:30 and 7:30 the "If" logic in both programs can never be true and the "Else" sections will always run. The time range will not work that way.
Yes I need the scenes to only run between 6:30 and 7:30. The only difference being if it's light outside a scene (summer) will run but if it's dark outside scene (winter) will run
Sent from my SM-G920W8 using Tapatalk
I am not sure I understand the intentions here. One can turn a scene on or off at certain time, but I don't understand the meaning of "running" a scene over a time period. And, what do you want to happen, and when, if sunrise is between 630 and 730 rather than before or after?
"Between" or from-to exactly?
From-to time conditions initiate Then - Else at only those two exact times. There will be time where a partial run may happen or they neither will run.
If you want one program to always run depending on season I would use a variable called say.. $Nightime.
Program Night.detection
..From sunset+10 minutes
..To sunrise-10 minutes
..set $Nightime to $cTrue (I define variable names as constants =1)
..set $Nightime to $cFalse
Program Event.trigger
..From 6:30 AM
..To 7:30 AM
..Run program Event.season
..Run program Events.stopAll (common off program/scene)
Program Event.season (disabled to stop self triggering)
..$Nightime is $cTrue
..Run program winter scene
..Run program summer scene
The sunrise times will not have your offset in them so some inaccuracies may be incurred but if the most important time is 6:30 and one always must be run this may do your job or be another route to contemplate.
Sorry just my wording scene on at 6:30 , scene off at 7:30
Another possibility (and second thought)would be to define a variable called $Winter that would be evaluated set every day. The time could be tweaked with experience.
Program Set_Season
..at sunrise every day
..run Program Set_Season.2
Program Set_Season.2 (disabled so times don't trigger)
..From 12:00:01 AM
..To 7:00 AM (adjust by experience)
..set $Winter to $cFalse
..set $Winter to $cTrue
Now the rest should be fairly straightforward.
Program Event
..From 6:30 AM M-F
..To 7:30 AM
..run program Event.season
..set scene winter Off
..set scene summer Off
Program Event.season (disabled but $Winter is not a state var. and won't auto-trigger anyway)
..$Winter is $cTrue
..set scene winter On
..(Wait 1 hour
..set scene winter Off = alternative to time range usage above)
..set scene summer On
Note that time frames filters are usually best in separate DISABLED programs because the end time triggers the else section if you are using code there.
How about this:
Program: Morning Scene A
   Time is from 6:30 am
   To 7:30 am (Same Day)
   Run Program 'Morning Scene B' IfPath
    Set Scene 'Summer' Off
    Set Scene 'Winter' Off
Program: Morning Scene B(Disabled)
   Time is From Sunrise
   to Sunset (Same Day)
   Set scene 'Summer' On
   Set scene 'Winter' On
The first program initiates an action at 6:30 to turn on a scene and at 7:30 to turn of both scenes (only one would have been on).  The second disabled program is called by the first and turns on the summer scene if the time is after sunrise or the winter scene if the time is before sunrise.
I believe this would fit the stated goal.
Hope this helps.
-Xathros
Edited by Xathros
How about this:
Hope this helps.
-Xathros
Yeah! what he said!
I was getting around to that in about another five-six hours but I had to warm him up first! :)
Edit: replaced minutes with hours
Thanks guys I will try these out. It sounded simple in my head just couldn't get it on paper
Always happy to help.
-Xathros
I use four programs, one for each season based on my location and one program to control the lighting (and window coverings).
Example season:
Fall - [iD 0056][Parent 0046]
        From    12:01:00AM on 2015/08/06
        To      11:59:00PM on 2015/11/05
    And Time is Sunset  - 10 minutes
        Run Program 'Sunset Lighting' (Then Path)
        Run Program 'Sunset Shading' (Then Path)
I do need to change the dates once a year, but ISY version 5 should alleviate that need. And you need only two programs B)
