Zigbee Thermostat Availability
Hi All;
I've searched through the various forums and I see a lot more information about Z-Wave thermostats than Zigbee, but my ISY has the Zigbee board (so that I can also connect to my house meter) and so I'd like to take advantage of that and get a Zigbee thermostat.
I see comments that the RCS TZB45 works well, but no one seems to sell it.  Does anyone know if it's available?  And are there other Zigbee thermostats out there that work well with the ISY?
Thanks.
Hi All;
Thanks.
UDI has been advertising the Zigbee TSTAT for quite sometime. But the advert indicates its for the IZ and not the ZS perhaps you should write in and ask if it will integrate with your current system.
This is the direct link for the TSTAT if it ends up being compatible for you listed as $249.XX: https://www.universal-devices.com/sales/
