Help with geofence program
Run Tools | Diagnostics | Event Viewer at LEVEL 3.
Change the variable such that the Program is triggered.
Delete Program which should show in trace as below
Change variable to trigger Deleted Program
Post trace
Tue 06/09/2015 09:07:33 PM : [        Time] 21:07:33 4(0)
Tue 06/09/2015 09:07:57 PM : [VAR  2    4 ]       1 - Program triggered when variable set to 1
Tue 06/09/2015 09:07:57 PM : [         X10]       A1
Tue 06/09/2015 09:07:57 PM : [X10-RSP     ] 02 63 66 00 06
Tue 06/09/2015 09:07:57 PM : [         X10]       A1/All Lights Off (1)
Tue 06/09/2015 09:07:58 PM : [X10-RSP     ] 02 63 66 80 06
Tue 06/09/2015 09:07:59 PM : [X10-RX      ] 02 52 66 00
Tue 06/09/2015 09:07:59 PM : [         X10]       A1
Tue 06/09/2015 09:08:11 PM : [VAR  2    4 ]       0
Tue 06/09/2015 09:08:39 PM : [D2D-DEL 0091] Program file '/CONF/D2D/0091.PGM' deleted
Tue 06/09/2015 09:08:52 PM : [VAR  2    4 ]       1 - Deleted Program does not run
Ok put me down on the idiot list... I didn't believe all this either, so a few days ago went through every program to make sure there wasn't any other instance of the notification, found none..Did that again and found one. The original copy of the program which I had renamed to find it easier...It seems to have stopped it...
(Normally more diligent before asking for help)
Sorry and thanks
(Begin name calling now)
Sorry and thanks
You won't be the last to do this to yourself. Most of us have done it too.
Thank you for getting back about this, though.
No worries mate!
