Is my ISY994i Pro Dead? No lights whatsoever
Hi,
I have no lights on my ISY 994i. The power adapter has the LED that indicates that it is on, but the ISY shows no lights. I tried unplugging it and plugging it back in , but no dice. Any ideas?
I would try to measure the voltage at the plug end of the power adapter to make sure you that you're actually getting power to the ISY.
Also try a different power supply.
With the power disconnected, try removing and replacing the memory card. If that doesn't help then I would suggest submitting a trouble ticket to UDI and let them troubleshoot it.
Did you try a different power supply? The ISY requires 5V, 300 mA minimum, so nearly any USB power supply will work.
