Something to think about
Techman
Being that there's no way to query a Range Extender to know if it's working, and some forum members have reported failures,  I've replaced mine with on/off modules which can be queried. It's my understanding that the range extenders are basically on/off modules or dual band lampllincs with some of the hardware removed.
Unfortunately a Query is communicating with the device over powerline (which may involve RF but no assurance).  Suggest running PLM Beacon test (4 taps on PLM Set button) to see the Range Extender LED response (color and blinking pattern) to determine if in range of PLM and on same/opposite 120v leg.
I agree that there's no way to test the RF portion without a tap test, It was my understanding that the failures of the Range Extenders was due to its power supply, possibly bad caps. A query should disclose that failure. Just a thought.
The Version 2, 2443 Access Points had the power supply problems. Same base board with caps as the 2413S PLM's
One of mine the LED was almost out and it didn't even try to start the Communications tests. My second one just didn't do the communications tests until I cycled the AC power to it.  Unregulated 12 volts {~18-19 volts} measured around  7 volts.
I don't remember seeing any of the 2992-222 Range Extenders being reported as having issues but I may have missed it.
Yes mine looks like the 2457D2 Dual Band LampLinc and it even has the same FCC ID:SBP2457D2A. As the Dual Band  LampLinc.
One of mine the LED was almost out and it didn't even try to start the Communications tests. My second one just didn't do the communications tests until I cycled the AC power to it. 24 volts measured around  7 volts.
I wonder if the Range Extenders have an Insteon address but it's just not published. It would be nice if there were some way to remotely query it.
Mine has the six digit Insteon ID on it. I believe it has a different Insteon Catalog and SubCatalog ID.
I will try again to add it to my ISY994i but if memory serves me it was an unknown device or just didn't answer to the request to add it.
Tried both Auto Discover and Start Linking.
Event Viewer Level 3.
Auto Discover:
Fri 07/17/2015 08:18:28 PM : [23 53 27    ] Added to list of devices to link to ISY
Fri 07/17/2015 08:18:28 PM : [iNST-TX-I1  ] 02 62 23 53 27 0F 0D 00
Fri 07/17/2015 08:18:28 PM : [iNST-ACK    ] 02 62 23.53.27 0F 0D 00 06                 (00)
Fri 07/17/2015 08:18:36 PM : [iNST-TX-I1  ] 02 62 23 53 27 0F 0D 00
Fri 07/17/2015 08:18:36 PM : [iNST-ACK    ] 02 62 23.53.27 0F 0D 00 06                 (00)
Fri 07/17/2015 08:18:45 PM : [iNST-TX-I1  ] 02 62 23 53 27 0F 0D 00
Fri 07/17/2015 08:18:45 PM : [iNST-ACK    ] 02 62 23.53.27 0F 0D 00 06                 (00)
Fri 07/17/2015 08:18:49 PM : [23 53 27 0  ] Failed to add device, reason 3
Fri 07/17/2015 08:18:49 PM : [All         ] Writing 0 bytes to devices
Start Linking:
Fri 07/17/2015 08:21:09 PM : Start Insteon Device Linking Mode
Fri 07/17/2015 08:21:09 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 07/17/2015 08:21:39 PM : [LNK-STAT    ] 02 53 M(01) gid=00 23.53.57 001D 42
Fri 07/17/2015 08:21:39 PM : [23.53.57 00] Linked device type=00.1D fw=42
Fri 07/17/2015 08:21:39 PM : [23 53 57 0  ] Added to list of devices to link to ISY
Fri 07/17/2015 08:21:39 PM : [LNK-BGN     ] 02 64 01 00 06
Fri 07/17/2015 08:22:12 PM : Stop Insteon Device Linking Mode, Final processing to follow
Fri 07/17/2015 08:22:12 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Fri 07/17/2015 08:22:12 PM : [iNST-TX-I1  ] 02 62 23 53 57 0F 0D 00
Fri 07/17/2015 08:22:13 PM : [iNST-ACK    ] 02 62 23.53.57 0F 0D 00 06                 (00)
Fri 07/17/2015 08:22:13 PM : [iNST-SRX    ] 02 50 23.53.57 34.E9.19 2F 0D 02           (02)
Fri 07/17/2015 08:22:13 PM : [std-Direct Ack] 23.53.57-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 07/17/2015 08:22:13 PM : [23 53 57 0  ] Calibrating engine version
Fri 07/17/2015 08:22:13 PM : [iNST-TX-I2CS] 02 62 23 53 57 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Fri 07/17/2015 08:22:13 PM : [iNST-ACK    ] 02 62 23.53.57 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Fri 07/17/2015 08:22:14 PM : [iNST-SRX    ] 02 50 23.53.57 34.E9.19 2F 2F 00           (00)
Fri 07/17/2015 08:22:14 PM : [std-Direct Ack] 23.53.57-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Fri 07/17/2015 08:22:14 PM : [iNST-SRX    ] 02 50 23.53.57 34.E9.19 23 2F 00           (00)
Fri 07/17/2015 08:22:14 PM : [std-Direct Ack] 23.53.57-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Fri 07/17/2015 08:22:14 PM : [iNST-ERX    ] 02 51 23 53 57 34 E9 19 15 2F 00 01 01 00 FF 00 A2 00 2B 96 A5 FF 1C 00 AD
Fri 07/17/2015 08:22:14 PM : [Ext-Direct  ] 23.53.57-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Fri 07/17/2015 08:22:14 PM : [23 53 57 0  ] Using Database Link Table offset 0x00F8 (reported 0x00F8)
Fri 07/17/2015 08:22:14 PM : [23 53 57 0  ] Failed to add device, reason 10
Fri 07/17/2015 08:22:14 PM : [All         ] Writing 0 bytes to devices
If I read the event viewer correctly It is a Catalog 00, SubCat 1D with a firmware of 42
The Auto Discover variation is using the wrong Insteon unless two Range Extenders were being used.
Auto Discover is using 23.53.27, Start Linking is using 23.53.57.   23.53.27 did not respond to the three command attempts.
Subcat 1D is not in the list of supported devices on 4.3.10.
Is It possible for UDI to add the range extender as a supported device, if so it could then be queried which would at least show if it's getting power. We could also then add notes to the device to show its location etc.
      37.5k
      375.1k
