KPL fade down problem
Hi everyone!
I have a light that is on the main buttons of a KPL. The light's level seems to be remembered just before it turns off. I created this program to test and explain the problem I'm having.
  - No Conditions -
       Set 'Bedroom light' On
       Wait  2 seconds
       Set 'Bedroom light' Fade Down
  - No Actions -
I ran the Then code manually from my computer. The code works fine. The light turns on and then fades off. The KPL is also in an Off state. The problem is the next time you use the KPL's On button. The KPL's On button lights up but the bedroom light doesn't come on.
After looking around I did find out that the bedroom light is actually on but at a 1% level. I think what is happening is that the 1% level is what the light was at last during the Fade Down process, just before turning off. When you turn it back on, it returns to that level.
Not sure if this is a KPL problem or something with the Fade Down process. Any thoughts are appreciated.
Ed
I don't quite follow, but I can tell you that a "Fade Down" will not actually turn the device off. You'll need to issue a "Fade Stop" at the end (maybe after a WAIT command) to get the device to register as "Off."
Thanks for the responses guys. I tried adding an additional Wait and a Fade Stop but that made no difference. I did find a different solution however.
First, I created a new scene called 'Bedroom light off'. I added the bedroom light (KPL) into the new scene all by itself as a Responder with an On Level = 0 and Ramp Rate = 2.0 secs. I then changed one line in my program from this...
to this...
Set Scene 'Bedroom light off' Off
It now works perfectly. I'm still kind of new to this and I'm still getting used to when to use programs and when to use scenes.
Thanks for your help.
Ed
I'm surprised the WAIT and FADE STOP did not work for you.
How many seconds did you WAIT for?
How many seconds does it take for the FADE DOWN to finish dimming your lights?
I made the Wait 10 seconds to make sure the fade down had time to complete. I think the fade down actually takes about 3 or 4 seconds. I'm not sure why it doesn't work but I can tell you it made no differnce.
