August 14, 201511 yr How to shift primary control to aeotec stick .so I can upgrade firmware. it is not being picked up by isy at all thanks Tom
August 14, 201511 yr Hi jetfan, http://wiki.universal-devices.com/index.php?title=ISY_Z-Wave_GenII_-_Instructions#Shift_Primary_Control_from_ISY_to_a_different_Controller With kind regards, Michel
August 14, 201511 yr Author Hi Michel , i tried several different ways . usb pluged into computer ,not pluged in , add device and change primary. This is z stick gen 5 zw090-A will this work? Thanks again
August 15, 201511 yr Typographical error (typo): Put the other controller in Learn Mode. Refer to the user guid for your product on how to do this. Put the other controller in Learn Mode. Refer to the user guide for your product on how to do this.
August 16, 201511 yr Author aotec 5 not recognized. And now z wave dongle .does not have add device anymore. and I cannot control any zwave device. do i have to factory reset and add evrything back? Or is there any other way. Thanks Edited August 16, 201511 yr by jetfan101
August 18, 201510 yr Hi jetfan101, It seems that the primary has been shifted to the other controller (that's why the menu is gone). Please try shifting it back ... I suspect aeotec 5 does not support all the nodes and/or secure devices you have. With kind regards, Michel
