EZIO4O ...
garybixler
Hello
I just received my first EZIO product (EZIO4O) and noticed that it has internal timers for turning off the relays after a set time. I don't want to add another controle system like the simplehomenet software and EZBridge to set them and was wondering if eventually the ISY will be able to set these timers. I didn't see anything mentioned in the forum about these timers.
Thanks in advance
Gary
Hi Gary,
We are now trying to figure out how to support EZIO again as everything seems to be broken.
Once we have this fixed, We will have the capabilities which will allow you to set the timers in EZIO.
Hello
Thanks in advance
Gary
  • 1 year later...
Just installed an EZIO4O for use on my ISY using the latest 2.8.1 firmware, and still had to use SimpleHomeNet's utility to set the timers.
I also had a problem with the ISY. If I turned on relay 0, the ISY marked relay 1 as being on, not relay 0 as expected. The physical output was correct.
Hi
I also noticed that on the EZIO4O that the admin console doesn't match the relays. Example, if I turn on relay 2 relay 3 shows on and so on.
Also firmware 2.8.1
Gary
This is a problem with the admin console display, the correct relay is being controlled. Also if the output relay is controlled through a Scene the correct relay state is indicated.
Can this device be programed to activate the sprinklers every Nth day (ie. Every 3rd day, 5th day, etc)?
I assume the question is in the context of the EZFlora Irrigation controller. The EZFlora hardware does not have that type of logic. When zones are activated is controlled by whatever automation software/firmware is controlling it.
      377.2k
