Program Not Running
zerop
Maybe someone could help me out.
Here's my program.
HallLightsTimer - [ID 0363][Parent 0048]
        Control 'Hallway / HallwayBed4WayLights' is switched On
     Or Control 'Hallway / HallwayEntry4WayLights' is switched On
     Or Control 'Hallway / HallwayGarage4WayKeypad' is switched On
     Or Control 'Hallway / HallwayMaster4WayLights' is switched On
        Wait  15 minutes
        Set Scene 'Hallway / HallwayLights' Fade Down
        Wait  7 seconds
        Set Scene 'Hallway / HallwayLights' Fade Stop
These four switches are a part of one scene with the scene on level set at 50%.
When I turn on the hallway lights using one of the switches it seems as if the program runs and then stops instantly.  When I look at the summary tab in the programs it says "Status" True and "Last Run Time" 9:09:50pm and "Last Finish Time" 9:09:50pm.
Here is the level 3 when I turned on the lights (if this helps).  I have no idea what all this in the level 3 means.
Tue 08/25/2015 09:09:50 PM : [iNST-SRX    ] 02 50 30.BE.F9 00.00.01 CB 11 00    LTONRR (00)
Tue 08/25/2015 09:09:50 PM : [std-Group   ] 30.BE.F9-->Group=1, Max Hops=3, Hops Left=2
Tue 08/25/2015 09:09:50 PM : [D2D EVENT   ] Event [30 BE F9 1] [DON] [0] uom=0 prec=-1
Tue 08/25/2015 09:09:50 PM : [  30 BE F9 1]      DON   0
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0363] CTL [30 BE F9 1] DON op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [iNST-SRX    ] 02 50 30.BE.F9 2F.B8.B2 40 11 01    LTONRR (01)
Tue 08/25/2015 09:09:50 PM : [std-Cleanup ] 30.BE.F9-->ISY/PLM Group=1, Max Hops=0, Hops Left=0
Tue 08/25/2015 09:09:50 PM : [iNST-DUP    ] Previous message ignored.
Tue 08/25/2015 09:09:50 PM : [iNST-SRX    ] 02 50 30.BE.F9 2F.B8.B2 41 11 01    LTONRR (01)
Tue 08/25/2015 09:09:50 PM : [std-Cleanup ] 30.BE.F9-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 08/25/2015 09:09:50 PM : [D2D EVENT   ] Event [30 B6 78 1] [sT] [127] uom=0 prec=-1
Tue 08/25/2015 09:09:50 PM : [  30 B6 78 1]       ST 127
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0365] STS [30 B6 78 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=127 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0316] STS [30 B6 78 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0013] STS [30 B6 78 1] ST op=1 Event(val=127 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0008] STS [30 B6 78 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 007B] STS [30 B6 78 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 00A5] STS [30 B6 78 1] ST op=1 Event(val=127 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 00A3] STS [30 B6 78 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D EVENT   ] Event [30 B2 75 1] [sT] [127] uom=0 prec=-1
Tue 08/25/2015 09:09:50 PM : [  30 B2 75 1]       ST 127
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0365] STS [30 B2 75 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=127 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0316] STS [30 B2 75 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0013] STS [30 B2 75 1] ST op=1 Event(val=127 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0008] STS [30 B2 75 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [iNST-SRX    ] 02 50 30.BE.F9 11.04.01 C7 06 00           (00)
Tue 08/25/2015 09:09:50 PM : [std-Group   ] 30.BE.F9-->11.04.01, Max Hops=3, Hops Left=1
Tue 08/25/2015 09:09:50 PM : [iNST-INFO   ] Previous message ignored.
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 007B] STS [30 B2 75 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 00A5] STS [30 B2 75 1] ST op=1 Event(val=127 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 00A3] STS [30 B2 75 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D EVENT   ] Event [30 EA 4B 1] [sT] [127] uom=0 prec=-1
Tue 08/25/2015 09:09:50 PM : [  30 EA 4B 1]       ST 127
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0365] STS [30 EA 4B 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=127 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0316] STS [30 EA 4B 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0013] STS [30 EA 4B 1] ST op=1 Event(val=127 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0008] STS [30 EA 4B 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 007B] STS [30 EA 4B 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 00A5] STS [30 EA 4B 1] ST op=1 Event(val=127 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 00A3] STS [30 EA 4B 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D EVENT   ] Event [30 BE F9 1] [sT] [127] uom=0 prec=-1
Tue 08/25/2015 09:09:50 PM : [  30 BE F9 1]       ST 127
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0365] STS [30 BE F9 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=127 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0316] STS [30 BE F9 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0013] STS [30 BE F9 1] ST op=1 Event(val=127 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 0008] STS [30 BE F9 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 007B] STS [30 BE F9 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 00A5] STS [30 BE F9 1] ST op=1 Event(val=127 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> false
Tue 08/25/2015 09:09:50 PM : [D2D-CMP 00A3] STS [30 BE F9 1] ST op=6 Event(val=127 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> true
Check the Folder Program HallLightsTimer is in.   Suspect the Folder has turned False which stops Program execution.
Nope, I don't have any conditions on any folders.
I do not have any new ideas at present. The Program is pretty simple. Once triggered with "If Control" it should Wait 15 minutes and then run the next statements. It should show "Running 'Then' " for those 15 minutes.
What ISY firmware is being used?
Does Help | About show same level for Firmware and UI?
Seems starnge huh?  I tried it several times and it didn't work.  Firmware 4.2.18, UI 4.2.30.
I've changed up the programming to make what I want to work so in the end this isn't a big problem.
Thanks for the help.
The Admin Console (UI)  is current but the ISY Firmware level is back level.   4.2.30 ISY firmware should be installed.   I've been running 4.3.10 (RC5) since it was released.   Expecting the next 4.3.xx image which will likely be the next Official release and last 4.x.x.
I would be concerned that 4.2.30 Admin Console running against 4.2.18 ISY could be causing issues.
Hi zerop,
I am not sure why you wouldn't upgrade to last official release of 4.2.30. What issues are you referring to with regards to mini remote?
Please open the Event Viewer, change the level to 3, and make sure you see DON/DOF every time you physically turn on/off those switches.
Hi zerop,
I am aware of that and that's the same bug in all firmware. It's not unique to newer firmware. I do recommend upgrading to the official release as we do not have a point of reference.
Not knowing which address corresponds to which device makes the referenced event viewer output not very meaningful to me. Do you get DON/DOF for EVERYONE of your motion sensors???
      380k
