MWareman Posted September 7, 2015 Posted September 7, 2015 I want to receive an email from my ISY when certain Elk zones change state (windows opened / closed etc). I've also been on a mission to remove spurious notifications when the ISY reboots (other than a single 'ISY has rebooted' notification). I'm down to my very last one now... and I cannot figure out a way to suppress the spurious notification at boot. Here is the program: Alarm Zone notify - [ID 010C][Parent 00B9] If Elk Zone 'Family Wndw Left' is Normal Or Elk Zone 'Family Wndw Left' is Trouble Or Elk Zone 'Family Wndw Left' is Violated Or Elk Zone 'Family Wndw Left' is Bypassed Or Elk Zone 'Family Wndw Cenr' is Normal Or Elk Zone 'Family Wndw Cenr' is Trouble Or Elk Zone 'Family Wndw Cenr' is Violated Or Elk Zone 'Family Wndw Cenr' is Bypassed Or Elk Zone 'Family Wndw Rigt' is Normal Or Elk Zone 'Family Wndw Rigt' is Trouble Or Elk Zone 'Family Wndw Rigt' is Violated Or Elk Zone 'Family Wndw Rigt' is Bypassed Or Elk Zone 'Family Wndw Side' is Normal Or Elk Zone 'Family Wndw Side' is Trouble Or Elk Zone 'Family Wndw Side' is Violated Or Elk Zone 'Family Wndw Side' is Bypassed Or Elk Zone 'Dining Room' is Normal Or Elk Zone 'Dining Room' is Trouble Or Elk Zone 'Dining Room' is Violated Or Elk Zone 'Dining Room' is Bypassed Or Elk Zone 'Office Window' is Normal Or Elk Zone 'Office Window' is Trouble Or Elk Zone 'Office Window' is Violated Or Elk Zone 'Office Window' is Bypassed Or Elk Zone 'Smoke' is Normal Or Elk Zone 'Smoke' is Trouble Or Elk Zone 'Smoke' is Violated Or Elk Zone 'Smoke' is Bypassed Or Elk Zone 'Sump Alarm' is Normal Or Elk Zone 'Sump Alarm' is Trouble Or Elk Zone 'Sump Alarm' is Violated Or Elk Zone 'Sump Alarm' is Bypassed Then Send Notification to 'Michael - EMail' content 'Zone Triggered' Else - No Actions - (To add one, press 'Action') The notification has the following details: Subject: ${elk.zone.#.name} Triggered at ${alert.date} ${alert.time24} Body: ${elk.zone.#.name} is ${elk.zone.#.status} All zones referenced in the 'If' show correct status in ISY - and they change to 'Violated' immediately when the zone is opened - and back to 'Normal' when the zone is closed again. Each time, I get the correct email. However - on reboot (during today's upgrade to 4.3.18) I got the following email (and only this one email): Subject: Office Window Triggered at 2015/09/07 09:27:01 Body: Office Window is Normal I performed a manual reboot (from the admin UI) and got the same exact message again (with a later and correct time). There is no other program referencing this notification customization - and I have confirmed that 'Run on startup' is *not* selected for this program. Any ideas? It looks to me like the program event system is initializing before the Elk module has established it's communication - then the initial retrieval of zone status is in fact triggering program evaluation. I'm expecting the program to trigger and evaluate 'True' when a zone actually changes - not during boot. Bug? Michael.
jerlands Posted September 7, 2015 Posted September 7, 2015 One method might be to incorporate an "Up Time" counter.. change the program to seconds.. if i.uptime > 60 Jon...
Michel Kohanim Posted September 7, 2015 Posted September 7, 2015 Hi MWareman, One method would be to have a program that with no conditions and have it run at boot up and set a variable. Have a program that waits 2 minutes when this variable is set and then set it back to 0. Use this variable as a condition in your program. The main reason for what you are seeing is that when ISY boots up, it queries ELK and thus that program will run. With kind regards, Michel
MWareman Posted September 7, 2015 Author Posted September 7, 2015 The main reason for what you are seeing is that when ISY boots up, it queries ELK and thus that program will run. That's what I thought was going on. It's just a different behaviour that Insteon (and zwave) devices. They (obviously) get polled on boot for current status (except most battery devices), but programs triggering on 'status' don't get triggered during this initial after boot poll. I was making an assumption that the behaviour would be the same for Elk zones. I'll create a boot timer as you suggest. Thanks! Michael.
MWareman Posted September 7, 2015 Author Posted September 7, 2015 One method would be to have a program that with no conditions and have it run at boot up and set a variable. Have a program that waits 2 minutes when this variable is set and then set it back to 0. Use this variable as a condition in your program. Perfect - works flawlessly. Squished that final annoyance in my system! Thank you.
Michel Kohanim Posted September 7, 2015 Posted September 7, 2015 Hi MWareman, Excellent. Just a word of caution: you will need to make sure the 2 minutes is indeed a good value. i.e. what happens if indeed something happens within those two minutes? With kind regards, Michel
MWareman Posted September 7, 2015 Author Posted September 7, 2015 Good point. I may break this out to two programs, the first for the normal zone status (with the trigger suppressed for the first 2 minutes) and the second not suppressed to cover the abnormal zone states. That way I'll get the notice is any zone is abnormal on boot. Thanks again for the tip! Michael.
shannong Posted September 15, 2015 Posted September 15, 2015 I use the timer method as Michel suggested but with a 30 second timer to control a "just booted" variable. That variable is used to suppresses some alerts like that, notify of a reboot, and controls a few other things.
