Woke up to red ERR light flashing?
ryanmead83
I got up today and all my lamps were still on and on the ISY it was flashing the red Err light, only that light nothing else.  Couldn't access it by the admin console either so pulled the power and it came back on right away.  Error log shows nothing, just shows the below so bit nervous now.  Any idea what would cause that out of the blue?
Sun 2015/09/13 06:46:17 PM System -5 Start
Sun 2015/09/13 06:46:17 PM System -110022 /CONF/INSTENG.OPT
Sun 2015/09/13 06:46:17 PM System -110012 /CONF/INSTENG.OPT
Sun 2015/09/13 06:46:24 PM System -110022 /DEF/F3/I1/NLS/EN_US.TXT
Sun 2015/09/13 06:46:24 PM System -110022 /CONF/UXT.BIN
Sun 2015/09/13 06:46:24 PM System -110012 /CONF/UXT.BIN
Sun 2015/09/13 06:46:26 PM System -170001 [Network] Established
Sun 2015/09/13 06:46:26 PM System -110022 /CONF/PORTALS.PSF
Mon 2015/09/14 08:52:21 AM System -5 Start
Mon 2015/09/14 08:52:21 AM System -110022 /CONF/INSTENG.OPT
Mon 2015/09/14 08:52:21 AM System -110012 /CONF/INSTENG.OPT
Mon 2015/09/14 08:52:29 AM System -110022 /DEF/F3/I1/NLS/EN_US.TXT
Mon 2015/09/14 08:52:29 AM System -110022 /CONF/UXT.BIN
Mon 2015/09/14 08:52:29 AM System -110012 /CONF/UXT.BIN
Mon 2015/09/14 08:52:30 AM System -170001 [Network] Established
Quick edit, the first start last night at 6:46pm was me starting it up after turning the power off to change a light.  Then 8:52 was when I got up and saw it off and restarted it.
Edited by ryanmead83
ERR blinking by itself indicates ISY File system problem.   Power down ISY and reseat SD card.  SD card may need to be replaced.
From as ISY User Guide
A blinking ERR LED indicates a file system error. Please power off the ISY and try to re-seat the SD card. If that does not help, the SD card may be defective. Please see Appendix C: Replacing / Upgrading Your SD Card
Edited by LeeG
Thanks so much, I saw that online and I powered it off and took the card out and put it back in. Not sure if the card fixed it as I didn't try restarting it without but I did see that online as well. Hopefully replacing the car doesn't mean losing all of my settings and devices, as buying a new card should be pretty inexpensive although it is odd to have a SD card fail.
I had a similar problem. I removed the SD card and cleaned the contacts with a SOFT rubber eraser, put it back in and its been behaving nicely every since.
Great thanks.  Man after all the trouble I've been having lately with my system that I finally just fixed, I definitely didn't need this!  I wish there was a camera on me to see my face coming down the stairs this morning to see the lamps still on!
We've all been there. Not to worry, it only gets better!
Hi Michel just sent it to you, hope that helps.  Mentioned in my email as well that the log might show a lot of start and stop (didn't look in detail).  Was having major issues with my network so was restarting it often to troubleshoot.  Turned out was a faulty GU10 light bulb, which after being removed brought the whole network back up.  So normally it wouldn't be power cycling that often.
      377.1k
