Status in Log
All of a sudden I have noticed many many status updates on several units in the Log. Most are related to a motion sensor at a time when no motion should be detected. Also several X10 messages are sent when not requested.
My PLM is at that magical two-year life span. Should I just go ahead and change the capacitors, which I have on hand, at this time? Or do I have some other problem?
Everything else is working smoothly, with no phantom activations.
Hi jmac,
Is the problem repeated during those times? If so, you might want to use the Event Viewer, change the level to 3, at/around the same time and see the traffic. As far as X10 messages that are sent: are they sent from ISY or are they received from ISY. Again, Event Viewer would be much more helpful than just looking at the logs.
