Backyard Dog Programs Part 2
Hi Guys,
My programs are working flawlessly thanks to those on this forum. My next step is to add a bit of logic and I cant seem to think it through.
See it's still warm here in Canada (not sure for how much longer) and when I let the dog out, we don't always close the sliding door, we may just leave the screen door blocking the entrance.
Now my program work flawlessly when I let the dog out to open and close the door the first time
Backyard Lights Night - [iD 0018][Parent 0060]
        From     9:15:01PM
        To      Sunrise + 15 minutes (next day)
    And (
             Control 'Sliding Door Open' is switched On
         And $Dog_Out is 0
        Set 'Backyard Keypad' On
        Set Scene 'Main Floor / Landscape Lights On' On
        Wait  15 seconds
        $Dog_Out  = 1
and then works flawlessly when the door is opened and closed again to let the dog in
Backyard Lights Night Off - [iD 0019][Parent 0060]
        From     9:15:01PM
    And (
         And $Dog_Out is 1
        Wait  20 seconds
        Set 'Backyard Keypad' Off
        Set Scene 'Main Floor / Landscape Lights On' Off
        Wait  15 seconds
        $Dog_Out  = 0
Effectively what I would like to do is add in some logic that says
If the sliding door is left open for a certain amount of time, say 10 minutes and then is closed, have the lights turn off.  Right now, if this happens based on the above programming, I would be required to open and close the door again before the lights will turn off.
How can i modify/re-write my program to make this happen?  Any help would be greatly appreaciated
Thanks all!
calberrt
I am not exactly sure how you want the two logics to combine. These lines of code may be able to be added in to your existing programs as they are later events than your code executes for.
From 9:15:01PM
And (
And
Control 'Sliding Door Open' is NOT switched Off
Wait 10 minutes
Enable program 'screen door only'
Wait 10 minutes
Disable program 'screen door only'
Program 'screen door only' (disabled)
Control 'Sliding Door Open' is switched Off
Set Lights Off, dog is in, etc.
